ok, heres an oddity.
my stock jug has a spacer plate between it and the bottom end.
i am running a STOCK crank, and a STOCK rod.
if i put the jug on without the spacer, the piston pops out of the top of the jug about 4mm (the thickness of the spacer), causing the piston to crash into the head.
bottom line is that it NEEDS the spacer plate.
spacer plate is NOT purchased, it is homemade, as the craftsmanship is not good quality.
i am asking possibilities of why it needs it. heres what i came up with:
1. Bottom end has been milled, but it still has factory dimples in the surface.
2. bottom of jug has been milled, but again, does not appear to be molested.
3. Top of jug has been milled. not molested, but it doesn't look quite right to me.
i am hoping the cases have not been milled, because then i will have to use this ridiculous plate when i install my 300 kit.
