Results 1 to 15 of 16
Thread: 350x cooling ideas
    gaukel350x's Avatar
    gaukel350x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2007
    El Cajon
    218
    350x cooling ideas
    Also to make the 350x run cooler could you put that little computer fan behind the oil cooler, would that work?
    What I own:
    1985 honda 350x
    1974 yamaha mx 125 aka "champ"
    1993 honda 110 mini bike
    1986 kawasaki 300 jetski
    1987 Ford Ranger Prerunner
    Rider for Life
    Feb 2006
    Central Florida
    1,090
    I have thought about it I have a 4 incher that has blue and red led's in it......
    quiet people seem intelligent
    hey, bigger cooler, auto trans cooler.
    one cylinder is not enough!!
    Mar 2007
    lakeville ma
    605
    duel oil coolers look under main page on how 2
    NO 3 WHEELERS CURRENTLY SOLD THEM ALL
    02 GSXR 240 kit STRECHED
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    670 ho skidoo powered banshee
    1985 nacs kx 80 race quad
    gaukel350x's Avatar
    Jun 2007
    El Cajon
    218
    Ya I checked that out and its impossible to do, I don't know how he did it. I need further instructions
    What I own:
    1985 honda 350x
    Rider for Life
    PA
    3,515
    without looking at it id say all you need to do is have the stock one hooked up normal but have the return line running to the second cooler and just run a new return line to the motor off the second cooler
    WWW.HREATV.COM
    gaukel350x's Avatar
    Jun 2007
    El Cajon
    218
    That's what I wanna do but I don't know where to mount the other cooler. I tryed what is under tech tips but I don't know how he mounted it. The gas tank is in the way.
    What I own:
    1985 honda 350x
    Rider for Life
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Theres two ways to go about cooler oil temps. More heat to surface air transfer (the oil cooler), or more capacity in the oil system, (inline resevoir perhaps)?
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    gaukel350x's Avatar
    Jun 2007
    El Cajon
    218
    Ya what I was also thinking, cause the 400ex has a oil canister that holds extra oil. That would be intresting if you could put that on the 350x. If you could thoe where would it mount up and wouldent it make the oil pump work harder?
    What I own:
    1985 honda 350x
    Rider for Life
    McDerry is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Maine
    440
    It shouldnt make the oil pump work any harder. The oil pump will still move the same amount of oil as before its just got a larger reserve of oil. Same concept as a oversized oil pan on a muscle car.
    The trick would be to mount it up at the same level as the oil in the engine so as to not create a way for it to drain down and overfill the engine as were not using a drysump application. Plumbing it in is easy, just run the return line off the cooler to it and then from the oil resevior to the return line on the engine. The desirable place to mount it would be behind the engine as its more protected. The swingarm would be most likely in the way though.
    Another thought on the cheap cheap, is find a small a/c condenser out of a car that will fit under the rear fenders laying flat. would add a very large amount of volume in addition to a large cooling grid.
    gaukel350x's Avatar
    Jun 2007
    El Cajon
    218
    Ya that would be a good idea, I'm gonna research
    What I own:
    1985 honda 350x
    Rider for Life
    Feb 2006
    Central Florida
    1,090
    you can etch the inside of your frame out and run oil through it
    it would take a little work but it would be cool
    gaukel350x's Avatar
    Jun 2007
    El Cajon
    218
    Ya that would be a good idea, ya kinda what like the xr 600 has and the newer 4 stroke 250s dirtbikes. I'm gonna experiment weld that on a beater 350x frame I have.
    What I own:
    1985 honda 350x
    Rider for Life
    Central PA
    1,952
    What about running an automatic trans cooler from a car, say underneath the frame where the engine sits. Just have to fab up a new skid plate to cover it so you dont bang it up.
    PastRides
    SOON MY PRECIOUS!
    Quote Originally Posted by Tri-Z Pilot View Post
    You would lose at least 2 inches of frame cradle to ground clearance and what about your engine oil drain plug?
    Lots of good suggestions here but Honda was one heck of a great engineer. This isn't being run on the BAJA 1000 and again, ya have to ask yourself what is going on or why is this machine running hot?? Here in the Northeast we have crazy hot and humid days, not to mention that 350X's were sold all over the world in all driving conditions.
    I'll bet it's running lean......
