Results 1 to 7 of 7
Thread: Axle Swap ...... Questions
    Feb 2005
    Orchard Colorado
    659
    I'm going to try and order a new axle for the '82 480R. I have heard that a '83 - '85 200X axle will interchange with the '81 - '82 250R... Has anyone ever done it and can confirm that it will?
    And does Durablue or anyone else make 200X axles?
    82R is the same as the 200X, thats all I can tell ya!!
    Jul 2006
    yes dura blue still makes a 200x axle but hold on it also requires the 200x axle to use a 81-82 250r sproket to work its the eliminator 2+2
    N/A
    5,818
    if you need a stock 200x axle i got one, you can use 400ex hubs and wheels and get 46" wide on a stock axle.
    Tionesta, PA
    5,745
    I just did this a couple of weekends ago - it is a direct swap. One minor mod - the 200X sprocket bolts need ground down about 1/4" to keep from rubbing on the carrier. So to answer your question - yes - it does work.
    Feb 2005
    Orchard Colorado
    659
    Thanks guys. I'm going to order one today or tomorrow.
    Feb 2005
    Orchard Colorado
    659
    I've tried to order an axle from RM ATV and Dennis Kirk. Neither will order the axle from Dura-blue. If I buy it direct from Dura-Blue it $482.00!
    Who knows someone friendly to trikes that would special order one?
