Results 1 to 15 of 17
Thread: my fan is in baby
    gaukel350x's Avatar
    gaukel350x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2007
    El Cajon
    218
    my fan is in baby
    So I went to the local junk yard shop and found some fans that would work, well since my 350x runs 12 volts AC, I thought a fan that was 12 DC wouldent work so I tryed it out and it did in fact work. I have it running on the hot side of my wiring so it runs without a switch. Hopefully it will help a little bit. I also hope it dosent make it worse.
    Current Attachments (24.7 KB)
    What I own:
    1985 honda 350x
    1974 yamaha mx 125 aka "champ"
    1993 honda 110 mini bike
    1986 kawasaki 300 jetski
    1987 Ford Ranger Prerunner
    Rider for Life
    Nightbiker07's Avatar
    Nightbiker07 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2007
    Toledo, Ohio
    382
    a DC fan wont last long on an AC current.........im suprised it works at all.......
    why do you need all this extra cooling? is it overheating?
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    little 6.5 HP minibike (Wicked Quick)
    2002 Ford Ranger, pulled out of a junkyard, fully radio-ified
    1969 Broncco TX-6 (yes its spelled correctly)
    92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
    I want to come to Trikefest 08!
    gaukel350x's Avatar
    Jun 2007
    El Cajon
    218
    Cause when I ride in the sand over here in the desert, its already 90-100 degrees and I want to try to get my 350x to run cooler. When it runs really hot it runs like crap. It bogs in 6th gear and seems to barely hit 45 miles an hour. I know the fan won't make a big difference but hopefully a tiny small one.
    What I own:
    1985 honda 350x
    Rider for Life
    Jul 2006
    western ny
    3,366
    there is a kick butt pc fan called "tornado" and all you should need is a voltage regulator to only allow 1 amp to go to it. they move major air and they spin at about 6000 rpm. those will kool it down a bit.
    GIT IT RAAAGGGGG !!!!
    Sep 2007
    Toledo, Ohio
    382
    sounds like a waste of time. rig up an oil cooler if you really concerned, the fan wont do crap unless your idling........
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    Jul 2006
    is that fan pulling or pushing?? good idea but I dotn see it benifiting anything
    Sep 2006
    nova scotia
    53
    Quote Originally Posted by Nightbiker07 View Post
    pretty sure that is on an oil cooler dont all 350x's come with one stock?
    Jul 2006
    yep oil coolers on the x are stock, honestly I would ad another oil cooler on the X somewhere even if its on the subframe, its still going to radiate some heat out of the oil, but if you get your oil not warm enough your engine may suffer as well, im sure that would only be a problem in the northern states though
    Jul 2006
    western ny
    3,366
    just find a fan that will move allot of air real fast and you will be ok. hell there are quads with cooling fans on them. do what you have to man. it doesnt hurt to try something new. but if that fan moves to slow it will cause more harm than good.
    Doesn't make sense, I haven't seen many posts about a 350X overheating and lots of guys run them in the dunes.....
    Mar 2007
    lakeville ma
    605
    Check your plug could b running hot because its lean!
    NO 3 WHEELERS CURRENTLY SOLD THEM ALL
    02 GSXR 240 kit STRECHED
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    670 ho skidoo powered banshee
    1985 nacs kx 80 race quad
    Sep 2007
    Toledo, Ohio
    382
    well,the fans in modern quads move tons of air.......get a bigger radiator if oil cooler isnt the answer. a bigger one will surely do the trick.
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    gaukel350x's Avatar
    Jun 2007
    El Cajon
    218
    It dosent overheat it just runs really hot. Ok let me tell you if what I'm running is right I have a complete supertrapp exhaust with 8 plates, I also have a k@n and my main jet is a 145. There is no engine work to my knowledge. How would you tell by the sparkplug if its running lean, I forgot what color.
    What I own:
    1985 honda 350x
    Rider for Life
    Ohio
    593
    Lean is whiteish.. good is light brown on cermaic, and black is rich
    gaukel350x's Avatar
    Jun 2007
    El Cajon
    218
    Then I guess I am running a little bit lean cause last weekend I went for a trip for 3 days and when I checked my plug it looked like there was a new one in there. It wasn't brown or white just straight white. Also does it matter what kinda of gas you run cause I run 91.
    What I own:
    1985 honda 350x
    Rider for Life
