Results 1 to 11 of 11
Thread: starting a 350x or 200x
    Aug 2006
    Texas
    997
    I kicked until I was out of breath on syks 350 and came close to starting it once! Is a 200x much easier to start? Im talking both trikes in stock form.
    84 Honda 200ES Big Red
    Jul 2006
    mind you guys my 350x has no decompresion cable on it as well, and im just a plain monstor, jason here weighs 140 with a 125 m.....lol
    hell my junkyard X was the hardest thing on the plannet to start soetimes, I hated starting that thing!
    bp739's Avatar
    bp739 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Southwest,Pa
    297
    My 86 200x seems to have way less compression than my 85 350x, and almost always starts on the 1st or 2nd kick...
    OH, no decompression cable.....yep that would meke a difference...for sure
    85' YAMAHA TRI-Z
    85'
    HONDA ATC 250R
    85' HONDA ATC 350X
    86' HONDA ATC 200X
    05' KAWASAKI KFX 700
    Ohio
    593
    my x has no decompress, I just give it a bit of gas and it starts first kick (that was with bad rings too.)
    Apr 2006
    PA
    1,464
    my 86 200x has a decompression cable and its pretty easy to kick. Gets tiring on the stop and go rides but its not hard to do and you can still kick it sitting down on the seat. Starts on 2nd kick usually too unless the plug is black since its running rich and needs to be cleaned once in a while. With a clean plug it starts 1st kick always.
    rugabugadouglas's Avatar
    rugabugadouglas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2006
    iowa
    269
    my 84 200x with a 12:1 com piston is a booger to start
    If it's jetted right and given a good healthy kick, it will start 1st or 2nd kick.
    I'm a believer that most carbs are jetted wrong or haven't been cleaned properly. Low compression, even though it "feels" good is another problem.
    Oct 2007
    Grosse Tete, LA
    3,440
    were you making fun of me right there dirtcrasher...lol.
    oldred95 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2006
    OK
    196
    Personally I prefer no compression release but thats me. I find that if I roll my 200x over a few times and then bring it up to compression is starts the easiest. Any engine seems to start the best when you bring it up on compression though. My dad used to have a 2 cylinder H John Deere tractor that was hand started and you could fight it all day or just roll it up to compression, give it a little nudge and it would take right off. It just takes time to learn the machine your working with.
    1984 200X bored .040 over, mild port work, K&N filter
    Planning on custom exhaust, XR200 carb and cam
    Nightbiker07's Avatar
    Nightbiker07 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2007
    Toledo, Ohio
    382
    lol, oh the wonders of starting ether.
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    little 6.5 HP minibike (Wicked Quick)
    2002 Ford Ranger, pulled out of a junkyard, fully radio-ified
    1969 Broncco TX-6 (yes its spelled correctly)
    92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
    I want to come to Trikefest 08!
    Aug 2007
    Moab, UT
    1,807
    Never use ether kid!
