Results 1 to 13 of 13
Thread: Bad news
    Mr.Jake's Avatar
    Mr.Jake is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2007
    Ontario
    192
    Thumbs down Bad news
    I went for a great ride with friends yeturday through mud, gravel pits, roads everything. My YTM175 ran great the whole time! But i got home and went to was it and realized the oil filler plug was gone. Looked in the hole and there was mud in there. Im pissed. Took off the left cover and took out the clutch and there was a fiar bit of sludge in there. I got 3 bottles of cleaner and some oil additive cleaner. My plan is to clean the clutch up and the insides around it. Then put it back together and add the oil stuff, drain it, add oil, drain it, and repeat this until the oil comes out cleans. Is there a better way to do this. i dread having to take the transmission apart and cleaning all of it in fear of not putting something back together right and have it not work. Any suggestions?
    Thanks Jake.
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Well if you dont want to take the tranny apart, I think you got it pretty well figured out.
    TF 07,08,09,10,11,12,13,14!
    Columbia
    5,131
    That really sucks!
    Other then taking it apart, your just going to have to flush it A LOT!
    Transmission fluid is real good at absorbing water, add some of that to the oil you put in. Ive also heard a lot of people useing deisel fuel.
    Head to walmart and buy a whole bunch of cheap oil, and just flush flush flush.
    Dec 2006
    St. John's Newfoundland
    1,587
    I would fill the engine with used oil, diesel, or cheap crappy oil, or tranny fluid. And just flip the bike around a little to get the oil everywhere. Then drain. I done this before and filled the engine full, completely full. I had water in a drowned 250sx. Work perfect after the drain off and fill up.
    Mr.Jake's Avatar
    Oct 2007
    Ontario
    192
    Ya i cleaned out the clutch are good, got the motor back in the bike and added oil and a whole jug of that additive cleaner stuff, idled it for about 5 mins, then drained it. I got a big jug of oil that im going to use to flush it a few times. Is the best way to do it to flush it, fill it up, idle it, flush it, and repeat. The oil comes out somewhat clean but i would like it better. Also where would i go to get a new plug? Im gonna check a couple small engine places tomorow. Hopefully its not a wierd sized plug.
    Thanks, Jake.
    Feb 2006
    Central Florida
    1,090
    run it a little bit and shift it thru some gears.. get the parts moving. these things are made for abuse
    quiet people seem intelligent
    Aug 2007
    williamstown new york
    66
    add deisel feul as previously stated be fore or kerosene also works good.. hopfully u can get it going and be riding it again
    "He who dies with the most toys wins..."
    ride it... break it... fix it.... repeat
    Dec 2006
    1,587
    You can get the plug at NAPA, Canadian Tire, just about any automotive store. They usually sell NGK, you just have to look for your plug number in the book they have there.
    Nightbiker07's Avatar
    Nightbiker07 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2007
    Toledo, Ohio
    382
    that sucks ass man. now imagine the oil DRAIN plug falling out on a few test runs before a day of riding.........man that KX80 tranny was smoked..........
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    little 6.5 HP minibike (Wicked Quick)
    2002 Ford Ranger, pulled out of a junkyard, fully radio-ified
    1969 Broncco TX-6 (yes its spelled correctly)
    92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
    I want to come to Trikefest 08!
    Mr.Jake's Avatar
    Oct 2007
    Ontario
    192
    brockey, i think your thinkin spark plug, im talkin oil filler plug. Im gonna look around today for one and get some tranny fluid and deisel from work tonight. Ill let ya know how it turns out and get some pics of our ride later on.
    I'll bet most of the plugs are the same thread, it's the length of the dipper that changes - depends if yours is a fill only or level indicating plug too.
    Was it rubber or steel? I have a Banshee filler plug you can have....
    Mr.Jake's Avatar
    Oct 2007
    Ontario
    192
    its rubber/plastic. i went to three small engine places and a tractor supply place with no luck. I made a temporary fix which is just a rubber with a bolt through it and when you turn the bolt is pushes the rubber out. It seems to work ok. Will a banshee plug work? The plug i had didnt have a dip stick on it, just a allen bolt that says fill level, which i assumed you were supposed to fill it until it ran out of the fill level hole, is this correct?
    thanks, Jake.
    trimoto.125's Avatar
    trimoto.125 is offline At The Back Of The Pack Arm chair racerFirst time rider
    kingston
    191
    Check out snowline sports in london,ontario. They have tons of trimoto parts. http://www.snowlinesports.ca/
