Be safe, get the 10.25:1. When you decide you want a little more and will pay the money for the racegas then step it up to the 12:1.
Ninja, what are the specs on the cam, or grind number (even if its custom they give it a number) Did you degree it in so its set properly? or just "thow in and go." How did you decide how you wanted it ground? Why would you have to grind the rockerbox? valves are only so long, no way the rockers could hit??? I can understand the guides being shortend for extremely high lift cams. Who did your porting? they match it to your custom cam?
With all that work you say you have done i coudnt imagine running it on pump gas. To not ping is amazing unless your cam isnt set right and killing your compression.
