Thread: 86 250r heads
    toyvette81 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    durham
    284
    86 250r heads
    just wondering if the stock heads have any more potential than stock? is there room for some porting and polishing or are they already worked to the max from the factory?
    1981 Corvette (chevy bright white)
    1998 GMC shortbed step side lifted,35's,mickey t's
    1995 Monte Carlo (gas mileagle car)
    1987 XR100
    1989 Polaris Trail Boss 250 (old reliable/faithful)
    1984 ATC 110 (Blue)
    1985 ATC 350x (DG exhaust)
    1986 ATC 250r cleannnnnnnn
    2002 polaris scrambler 500HO 4x4 (supertrapp exhaust)
    75 jeep cj5 6" lift, 35" procomps, locked up,
    77 jeep cj5 3" lift, 34" tsl's
    67 jeep comanche(running soon)
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    There is room for improvement!!!
    You can have porting done,B Cool head,Wiseco Piston with a ceramic coating.
    durham
    284
    b cool head? is that aftermarket im just talking about things to do to the stock head
    1987 XR100
    1984 ATC 110 (Blue)
    Jun 2003
    englishtown NJ
    2,676
    improvement can be made by shaving the head and using a cr250r head gasket, but now you are taling race gas territory. There really isn't too much you can do to a stock head.
    durham
    284
    what will using that cr250r head gasket bring my compression to? do you know ? your talkin 106 or 110 right?
    1987 XR100
    1984 ATC 110 (Blue)
    Jun 2003
    englishtown NJ
    2,676
    I believe its a 89 cr250r gasket, many of the top end and full gaskets sets have an option for a thick trx gasket or thin cr gasket. I know I got a few of them from those gasket sets. With a shaved head and cr gasket, you will be in a compression where race gas is a must. The cost and availabiltiy of gas is the down-side of going hi-compresssion.
