Results 1 to 9 of 9
Thread: 250es vs. 250sx carb?
    jasonb01's Avatar
    jasonb01 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2006
    Baton Rouge, LA
    166
    Are there any differences at all with these 2 carbs? Are they both jetted the same? My es's carb is leaking, I need to get a kit for it, but my sx's carb has been recently rebuilt, but I have other issues with the sx and need the es now to do some work. Just don't want to mess up my Big Red any, cause it is pretty clean. If it matters, the sx is an 85 and the es is an 87.
    Just out of curiosity, are these motors the same with the exception of the color? One being black. Is that the only difference?
    Thanks!
    1987 Honda 250ES Big Red
    1985 Honda 250sx
    1985 Honda ATC110
    I think the Clymer manual covers both and should show the carb. I'd bet it was the same and if it is, grab an 86/87 250SX carb and don't but another 85 carb.
    springville, PA
    6,185
    I have never had a problem with the '85 SX carbs, whether it be cold start or otherwise and thats including the 3 I've owned and the 4 Brapp has owned, none of which had the cold start kit installed. Toss the carb on and take it for a rip, I bet she will haul
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    jasonb01's Avatar
    Dec 2006
    Baton Rouge, LA
    166
    Cool! Thanks fellas!
    1985 Honda 250sx
    1985 Honda ATC110
    Feb 2006
    Central Florida
    1,090
    theres a cold start kit? hmm - the es I picked up yesterday supposedly is hard to start.
    I have the option too - either an 85 sx or es carb for the es. There is no difference is there?
    quiet people seem intelligent
    springville, PA
    6,185
    Quote Originally Posted by rally4x4racer View Post
    Its a richer pilot and some rubber plugs. Its discontinued
    The hard start issue could also be valves, listen for the gremlins tickin away
    Nate
    R.I.P HRR
    Sep 2006
    S.E. LA
    700
    The 86/87 carbs also have a different hose setup, unless that is also included in the cold start kit.
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
    Feb 2006
    Central Florida
    1,090
    i can make rubber plugs 250.... and a pilot should be avail right?
    im going to try swapping it with a clean sx carb first and see if that helps.
    valves are good - engine runs great
    I would simply find the drill bit that fits the stock starter jet and go up a size or two in a drill index and drill it out until it fires well in cold weather.
    The rubber hoses do nothing besides "combine" all the vent hoses.
