I just replaced the main jet in my carb and now it is dumping fuel out of the hose above the idle adjustment when I turn the fuel on?
Any suggestions?
Thanks,
Any suggestions?
Thanks,
For some reason your floater is geeting stuck. Your carb may need to be cleaned.
you mean the float in my bowl?
Clean the whole carb out , with Compress air , Carb Cleaner ...
Make sure you seat the Needle Correct .....
Sometimes Tapping it Few Times will work
i've fought with that on my 200x and on one of the 70s we're building. just check your float.
check if when reattaching the carb bowl that you aren't pushing against the float and causing it to stick.
ya if i were a betting person id bet its yer float
"He who dies with the most toys wins..."ride it... break it... fix it.... repeat
It was the float. the pin fell out.
Thanks for all the responses.
no problem. Thats why were here!! to help each other.
