Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 42
Thread: Looking for ESR ATC 5 Pipe
    Oct 2007
    Oregon
    46
    Looking for a ESR atc 5 pipe for 85 honda 250r
    Hit me up if you got one or know of good deals
    Thanks
    Sep 2005
    Lipetsk, Russia
    2,824
    Get one from ESR? They still make them. Or try and score one off of Sleaze-Bay.
    I'm back in the USSR...
    Oct 2007
    Oregon
    46
    sleaze bay?
    Nov 2006
    Florida
    1,663
    that's code name for ebay
    RID3R's Avatar
    RID3R is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    VA
    399
    aka e-gay..
    Sep 2005
    Lipetsk, Russia
    2,824
    aka FleaBay
    Aug 2007
    Moab, UT
    1,807
    Enough with the aka's!
    Nightbiker07's Avatar
    Nightbiker07 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2007
    Toledo, Ohio
    382
    lol most of the stuff that went on my bike came from ebay......never had a problem.
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    little 6.5 HP minibike (Wicked Quick)
    2002 Ford Ranger, pulled out of a junkyard, fully radio-ified
    1969 Broncco TX-6 (yes its spelled correctly)
    92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
    I want to come to Trikefest 08!
    Oct 2007
    Oregon
    46
    lol thanks for the help ful post...
    Nov 2006
    Florida
    1,663
    Seriously check ESR I'm pretty sure they still make it. If not look at the Paul Turner High Rev pipe or then ebay for a custom sectional. Those will be your best choices
    Oct 2007
    Oregon
    46
    I know they make ATC 5 pipes on ESR site, $250 for them, just wondering if anyone was gettin rid of one. Should i get an esr silencer to go with it?
    Also was debating about the high rev pipe with fat boy silencer.
    Is one setup better than ther other? or bout the same?
    Fresno Ca
    2,695
    Theres a reason you never see Esr pipes for sell. I see ptr pipes for sell quite often. Go with the ESR. lower hitting powerband and doesnt let off on top. Ptr pipe is too hight hitting of a powerband.
    Phoenix, AZ.
    6,719
    I don't know where you're getting your info on Paul Turner High rev pipes. Are you comparing Banshee pipes or something? I've ridden R's with the ESR pipes and they're nice but nothing to write home about. The high rev on my R is not a peaky pipe at all. The biggest improvement over the FMF was actually it added a ton of low end and the power comes on way lower than it did before. Totally smooth delivery and still revs out. Most of the other guys on here with High Revs will tell you the same thing. The name is misleading.
    Edit: and where do you see used PT high rev pipes for sale all the time? I looked for a year and only found one that turned out to be a beat up piece of junk. I see them for the TRX sometimes, banshees often, but almost never for a 250R trike. I had an automatic search setup on ebay so everytime anything with the name Paul Turner was listed. Not one single R high rev pipe showed up that entire time (12+ months). The one I eventually did find was mislisted (Paul Tuner).
    Oct 2007
    Oregon
    46
    Well thanks for the info . I havent really found anything on either of them. Notice like two PT pipes on ebay. Might have to break down and get one off the net. There was a guy on here telling me he had a pt for sell but he takes like 3 days to get back to me lol, duno whats going on with that
    FOR SALE85 ATC 250r
    +6" extended swing arm
    +4" axle
    FMF Fatty Pipe
    DG Silencer
    Cool Head
    Boyesen Reeds
    Keihin Carb
    Wiseco Piston
    K&N Air Filter
    Phoenix, AZ.
    6,719
    Be careful when shopping for a used PT. There are three different ones you're going to run into. The High Rev (best one by a mile), the Type 6 and the ones that don't have a name stamped onto them. From what I've seen, The no name ones are usually a type 6 and not the High Rev. Also be warned, the TRX250R pipes DO NOT fit the three wheeler. There are three PT 250R pipes on ebay right now. Only one of those will fit a trike and it's not clear in the pictures which model it is.
