i want to put my 200mforks on my 200s triple tree this application will make the 200m forks about 1.5 to 2 inches closer. the ? is will the brake from the 200m fit with the 200s wheel, or what other options might i have for wheels?
If it doesn't fit I can sell you a 200s brake assembly with new shoes. That is if thats what you need.
i'm using the 200m sliders so i think i need to use my 200m brake assy? i dont know if the s hub will work with the m sliders? and i dont know if the m wheel will fit in between the forks now that they are closer.
if your using the 200s triple tree with 200m shocks/forks you will need a 200s front hub, spacers, and axle. if you were to use a 200m triple tree with 200s shocks/forks you would need a 200m axle, spacers, and brake hub. the 200m front ends are wider than the 200s.
down to parts because i no longer have a place to ride trikes.![]()
GIT IT RAAAGGGGG !!!!
