I cant get it apart, maybe im stupid or is there a nack? I need this cable to fit my 38 mm carb on the 265! So i need to get my cap that came on the cable off to fit my 38
help me lol
help me lol
RPFLU member and co-owner.
Hardtails is all we do.
#NOLINK
#MAKEHARDTAILSGREATAGAIN
#SUSPENDTHIS
you can buy cables from Motion Pro that have a cap biult in for a 38mm carb/
JASON LISKEY
2 = 86 atc 350x's
86 atc 250r
Well crap lol
This has a built in cap for the stock carb, time to taker back!
#NOLINK
#SUSPENDTHIS
yep you can buy them with either size cap.
JASON LISKEY
2 = 86 atc 350x's
86 atc 250r
Thanks jason, any help on the clutch pull while your here?
magura?
#NOLINK
#SUSPENDTHIS
i just use the stock stuff. maybe your cable is frayed inside the housing where you cant see it. my trx needs a new one because of that.
JASON LISKEY
2 = 86 atc 350x's
86 atc 250r
Alright, thanks, im thinking magura hydro system. But ill try a new cable first
#NOLINK
#SUSPENDTHIS
C'mon Josh...you've ridden with the OTC enough to know that several of us are running the MSR Pro Raptor easy pull clutch assembly and really like it. Screw all that high dollar hydro crap. Just drop the 40~50 bones and get the MSR setup.
As far as your throttle cable...I picked up a brand new MP cable a while back and found that it just takes a very extreme tug to get the cable clear of the cap. It's held in with a little c-clip ring and when they are brand new, they are very stiff and tough to compress enough to get the cap separated.
Official Wellsville soil tester! With pics and a $3000 medical bill to prove it...
1986 TRX250R
ESR 310~trail ported w/ torque exhaust flange~36mm Keihin carb~v-Force3 reeds~Pro Circuit Exhaust~custom 16oz flywheel weight~2006 YFZ front shocks~adjustable rear dogbone~fully functional rear brake light~Durablue +4 axle
Former Ride 1986 ATC250R
Todd your the man! Thanks alot brother!
And that MSR Deal, seems I have found a new soulution!
#NOLINK
#SUSPENDTHIS
