Page 5 of 5 FirstFirst ... 3 4 5
Results 61 to 71 of 71
Thread: '83 ATC 480R Starting The Fabrication
  1. #61
    Apr 2010
    central minnesota
    462
    Still no updates?
  2. #62
    Nov 2006
    southern oregon
    2,338
    bump. curious if the 2nd gen swap worked out.
    2-stroke lover
  3. #63
    sbjones73's Avatar
    sbjones73 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    wisconsin
    414
    any idea on price for the mounts ? and then for the mounts with the shafts?
    thanks
    84 250r gone,
    87 suzuki lt250r trail machine, gone to fund ice racer,
    85 250r ice racing project started !!!!!!
  4. #64
    Mar 2011
    New Jersey
    4
    Iam REALLY interested in a kicker set up. I have had a cr480 bolted up in a 84 ATC 250r for about 3 years and I came to a halt at the kicker and the pipe. The engine is all rebuilt too. That's about all I need. What did you do for a pipe?
  5. #65
    Worcester, MA
    1,117
    Brokenmike - can you use it, you just need it to kick forward to clear the fenders? I may cut the left side fender off to fit on my 82R......
  6. #66
    buffalo new york
    46
    Here is what i did. I extended the kicker 3 inchs out from the motor and took out and inch in the length (made it lovely to kick),and made the peg removable with a quick release pin. let me explain the peg a little better. Drill the threads out of the peg mount (the threaded part on the frame). take the peg and weld a peice of round stock in the peg bolt holes. insert the new modded peg into to the frame and drill a very small hole through bolth the frame part and the round stock part of the peg. go to home depot and get the quick release pin first. They look almost like a safety pin. If you would like to see this i did on my 84 200x with a 84 cr500 in it posting. hope this helps, if not its my 2 cents.
  7. #67
    Mar 2011
    New Jersey
    4
    My problem is the kicker hits the frame. I only need to come out about 1" 1-1/2" so the kicker will clear the frame. I have never tested it with fenders
  8. #68
    May 2011
    naples, maine
    42
    Hello bigbore, im building a ATC480r trike, and was woundering if you had the bolt up kit for this motor. Its going on a 83 ATC250r.
  9. #69
    Feb 2008
    Ellensburg, Washington
    I have a complete 1983 480R engine for sale if anyone wants to do the swap. Comes with complete top and bottom engine, carb, intake, and coil.
    84 250R
    2003 Polaris Trailblazer 400
    2005 Raptor 686
    1985 Kawasaki 550 jet-ski
    1996 Yamaha Waveblaster II
    1996 Skidoo Summit
    2011 Triumph Thunderbird Storm
  10. #70
    Ripley Tn
    1,363
ID:	147628 dont if this is it or not but found this pic today
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
  11. #71
    Oct 2012
    Kentucky
    43
    Bump
    Was this project finished?
