Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 45
Thread: Hydroformed exhausts. Expansion chambers and Megaphones
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Always wondered how they did this, I use to think they were just stamped out and welded together but I now see I was wrong! http://www.eurospares.com/frame8.htm and this one too: http://www.two-stroke-addicts.freese.../hydropipe.htm
    Oct 2007
    England
    143
    Thanks, Its great to learn little tricks like this.
    Thats cool.. I have seen it done with just air
    PA
    3,515
    thats pretty cool
    WWW.HREATV.COM
    Sep 2005
    Missouri
    469
    About 8 years ago, I toured Rick Ritter's shop (RCR) and he hydroforms his polaris pipe. He had stacks of pipe sheets cut out from a cnc plasma. He used a powerwasher to supply the presure needed to form the pipe. Then with the water drained, he would pressure the pipe with air and would heat the seam with a torch and it into shape. Then grind down all the seams and reweld them.
    Apr 2003
    HARTFORD CT, USA
    478
    cool
    same here seen it done with air before but not water.
    'WHEN IN DOUBT.........GAS IT!'
    87 KXT250B2 Tecate
    86 ATC250ES BIG RED
    85 ATC350X
    85 ATC70
    'A FEW IN PARTS'
    Live Oak, FL
    15,069
    Whew, I'd be scared to use air. If one ever popped, it'd be just like a balloon but instead with sheet metal for shrapnel I dont know the exact physics behind it, but from what I was reading the reasoning for using water was because if there is a leak or something, all the pressure drops instantly and the power/force is dissipated a lot safer then if it was just compressed air. I've gotta try it someday though, I bet it works extremely well.
    Ohio
    593
    wow, someone should start making new custom pipes!
    Nov 2007
    Madisonville, KY
    15
    Hmmmmm.....I wonder if that technique can be applied to making a gas tank. I'm thinking the seams wouldn't be strong enough to hold that much pressure. An exhaust could, I'm going to give it a shot. Also might want to braze over the welds, might make it safer because brazing is typically used in raditors and repairing hydraulic lines. A weld will hold the metal together with a relative of 60k psi and the braze over that will stop leaks and give it added advantage. Only danger is the metal giving and not the weld, IMO.
    But very, very cool!
    Masshole
    2,191
    Very interesting read. I never gave it much thought until this. Thanks for sharing!
    Fresno Ca
    2,695
    hmmm intresting, but every pipe ive ever see is eather a coned sectional or stamped pipe. Never seen one anything close to those
    Live Oak, FL
    15,069
    Actually this is how the ones that look like their stamped are made. The only ones that are truley stamped are the OEM ones.
    May 2007
    Coshocton, Ohio
    1,815
    I'm not sure about the physics either but I do know that water can't be compressed like air.
    Appalachian American Racing
    the home of
    May 2005
    Bloomington, MN
    112
    Quote Originally Posted by Daddio View Post
    If I were to take a guess, it would be that they probably heat the steel to a certain temperature to make a easier to work with, and then they pump water in with incredible force before the steel gets a chance to cool down. It seems strange to me that water could do that.... maybe the water pump just keeps forcing water in until desired shape? They might even have to give it alittle motivation with a ?
    '85 Tecate (MX project) ***PARTS WANTED***
    ***PM me if you have any parts for an '84-'85 tecate that are for sale or could possibly be for sale (anything and everything considered)***
    Fresno Ca
    2,695
    I know esr gets there stamps from a company in nor cal, the come curved. From what ive herd. Almost all 2 stroke pipe makers go through them, They give these guys a pipe, they make a mold off of it and make stamps to fit around the mold.
