Power Pros? The reason I said what I did is because, if you look at all the aftermarket pipes that are not coned sections, you will see they have a weld lines that are relatively flat. I'll use my FMF 250R pipe for an example. Because your only working on one plane, you have cut out and Hydroform the pipe in sections, and then weld it together. Thats where the multiple pieces come in the design. Actually stamped pipes, like a stock 250R one, have an external thin ridge that runs the full length of the pipe, usually like a1/4 inch high. Those are stamped.
