Results 1 to 8 of 8
Thread: What does this mean?
    Jonathan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    I finally started tearing my 200x motor apart the other day and my piston has "0.75" stamped into the top of it. What does that mean? Oversized? Thanks for the help, I'm sure I'll need some more in the future.
    Detroit, MI
    837
    It could mean it's .75mm taller piston for higher compression. Possibly a 12-1 or 10-1 piston? I do not know, just a guess.
    1986 ATC 250R(for sale), 1963 AceCraft boat w/40HP Evinrude, 1981 Arctic Cat El Tigre' 440 L/C, 1992 GMC Safari Van.
    Billy Golightly's Avatar
    Live Oak, FL
    15,068
    If its a wiseco its the oversize, thats where they stamp the oversize at. I've never heard of a .075 over bore...First time for everything though I guess.
    New Hampshire
    794
    First off, it says .075. If your engine was running a piston .75 over stock, your timing chain would be "incoporated" into the combustion chamber.
    Honda typically did their overbores by .025, .050, .075, .100 , so it is likely a Honda piston.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Sudco does the same thing. I am 99% sure the piston is 3rd over size. With that much over you might have another 1-2cc of power. lol
    Quote Originally Posted by JohnnyBlaze
    No, it actually says '0.75', not '.075'. I'll take a picture tomorrow.
    Guest
    You are dealing with a product that was designed and manufactured using the metric system. My guess is that the piston is 0.75 millimeters larger than the standard piston. Why don't you measure the piston or get someone else to measure it? The conversion factor between inch and millimeter is 25.4 mm / inch. Therefore a 0.75 millimeter oversize piston would be about 0.030" (inches) larger than the stock size.
    GlennMc.
