Results 1 to 2 of 2
Thread: Rebuilding Tri-Z motor
    VenomRS4 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2007
    Massachusetts
    418
    Well, its just about time to rebuild the Z motor. Ive only rebuilt one other motor before and this is going to be my first time doing this motor over. So I want to make sure I am not missing anything.
    Heres what I have so far:
    New Piston, rings, crank bearings, seals, wrist pin bearing, full gasket kit, new clutch discs, and some gasket material....and lots of threadlock.
    So, what am I missing....if anything?
    My current stable:
    1981 Honda ATC110 (sold)
    1986 KTM 80 MX (for sale)
    85+86' KTM 500MXs (sold)
    1973 Yamaha AT3 125
    1971 Suzuki MT50 Trailhopper
    2005 Kawasaki Ninja 250 (for sale)
    2000 Ducati SuperSport 900ie (for sale)
    Nightbiker07's Avatar
    Nightbiker07 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2007
    Toledo, Ohio
    382
    the bearing on the bottom of the rod that attaches the rod to the crank. might as well get a rod kit, comes with the bearings and new rod.
    you will have to send the crank out to have it installed though, since its a 3 piece crank, and its press-together.
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    little 6.5 HP minibike (Wicked Quick)
    2002 Ford Ranger, pulled out of a junkyard, fully radio-ified
    1969 Broncco TX-6 (yes its spelled correctly)
    92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
    I want to come to Trikefest 08!
