First off, welcome to 3 Wheeler World!
Next, lets find out what you have. There are a few possibilities from what you described, it could be a.....
1983-1984 YTM 200E: 4 stroke, shaft drive, front suspension, electric start
1985 YTM 200ERN: 4 stroke, shaft drive, front suspension, electric start, reverse
1983-1985 YTM 225DX: 4 stroke, shaft drive, front suspension, electric start, rear suspension
1985-1986 YTM 225DR: 4 stroke, shaft drive, front suspension, electric start, rear suspension, reverse
As for the bearings, I usually order mine from denniskirk.com or you can get them from a member here (username: dads). Maybe someone else will post up the numbers, I don't have them. I have brought them in to a bearing shop before and they matched them up, same with the seals (yes, it’s a good idea to replace the seals as well). All in all it shouldn't be more the $20 for the bearings and seals.
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
