Results 1 to 15 of 27
Thread: 350x smoking
    350xrider911 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    porter texas
    301
    350x smoking
    hey every one im new here and i need some help on my 350x so far i had it bored .5 over 10.25 compresion piston port and polished head it smoke after i did this and when it got hot and warm it quit i thought valve guides i had the head redone and now it smokes all the time i did have i valve bent u couldnt see if it was bent but i the guy at the shop sed it was and he replaced it
    Jul 2006
    well first off HOLA GRINGO!! now for your 350x smoking how many hrs has it been since its been built? it may need alittle more time to seat the rings, im not big into the 4 pokes even though I just picked up a 350x, it smokes alittle but its ok, it kinda reminds of my 2 strokers! lol!
    Nov 2007
    porter texas
    301
    i broke it in like this sit powroll told me to but i at least have 10 hours on it
    Feb 2006
    Central Florida
    1,090
    what color smoke?
    post a link the the powroll break-in procedures pls
    quiet people seem intelligent
    Nov 2007
    porter texas
    301
    i printed it out a couple moths ago now i cant fine it but it says start the bike do notlet a freshly rebuilt motor sit at idle keep at a mid hi idle use fan to help keep the heat down then shut it off let it cool completle off then ride it for 20 min let cool completle do it like 3 times and its white smoke ill ride it and hour check the oil and it all gone
    Nov 2007
    porter texas
    301
    any one plz!
    Nightbiker07's Avatar
    Nightbiker07 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2007
    Toledo, Ohio
    382
    hmm....white smoke you say?
    are you certain it is not a blue-ish smoke? blue-ish is oil use.
    take a real good look at the smoke cloud. it is probably oil use, but
    in cars, white smoke is usually antifreeze getting into the combustion chamber.
    fill the oil up, then run it around for a while, and periodically check the oil and see if the oil level decreases.
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    little 6.5 HP minibike (Wicked Quick)
    2002 Ford Ranger, pulled out of a junkyard, fully radio-ified
    1969 Broncco TX-6 (yes its spelled correctly)
    92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
    I want to come to Trikefest 08!
    Nov 2007
    porter texas
    301
    ok today i pulled the head pipe off and it was wet it didnt smell like burnt oil or gas like a rich oil
    Jul 2006
    maybe the bore has alittle to much clearance in it allowing some oil past.
    Nov 2007
    porter texas
    301
    when i got the cylinder back i flet the side of it and u know those cards that wen u telt them they change pictures well it felt like that it just dont fill right
    Jul 2006
    did they hone it?? sounds like they may have done a crapy job or they didnt bore out all the scratches in it left behind by the old piston
    Nov 2007
    porter texas
    301
    i called the guy that did it and sed i might of honed it does any one know what it might caost for new rings for a .5 over wiseco piston
    Jul 2006
    around 30-40 and might of honed it?? who honed it? you or him? im confused! if you sent it to a machine shop for a bore they should have finished honed it for you.
    Nov 2007
    porter texas
    301
    he sed he might of honed it i didnt hone it
    Jul 2006
    he might of? he dosnt know? man...... I would find a better place to get your stuff worked on man! thats probably the problem!! its not been bored and honed correctly, he sucks!
