Results 1 to 4 of 4
Thread: tecate carb swap. got a question
    Jul 2003
    indiana
    892
    I swapped a pwk36 onto my 85 tecate and the only problem I have ran into is the throttle cable seems to be to long? What are you guys using for a cable or am I simply overlooking something? Thanks
    Sep 2006
    Shreveport, Louisiana
    888
    I'm using a stock setup off a '01 KX500, cable and twist throttle on a 39PWK. Length is perfect.
    What throttle are you using? Why is it too long? Can't you adjust it to be good?
    >>>>>>>>>>>>>>>2007 Yamaha Raptor 700R>>>Cross Country Racer<<<<<<<<<<<<<<
    www.myspace.com/bluelionracing
    Support my 2009 sponsor:
    For all your ATV suspension needs.
    Nov 2006
    southern oregon
    2,338
    You may have to buy a new cable... the stock mikuni has that solid elbow coming out of the cap that the kiehin doesn't... just about any KX cable should do the trick...
    2-stroke lover
    Jul 2003
    indiana
    892
    I am running the stock cable and I have it adjusted it to the max. I tore apart the brass elbow on the mikuni carb so I could get the cable out of that and got it put into the pwk. I will look into a kx cable but I am going to mess around with it a little today and see if I cant get it to work correctly. I'll let y'all know what happens.
