Results 1 to 7 of 7
Thread: RD/Tri-Z 400?
    ColeTrickle's Avatar
    ColeTrickle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    New Hampshire
    247
    RD/Tri-Z 400?
    I have a Yamaha RD 400 that I'm thinking of turning into a trike or using the engine for one of the Z's I have to put together. Any one try this before? The RD is a 400cc twin cylinder, air cooled two-stroke. I have the 400 all apart now waiting to rebuild the crank, after that I'll put the engine together and see how close it comes to fitting in a Z frame.
    Aug 2004
    Phoenix
    1,229
    Here's a pic of a conversion done by a guy I knew. Its an RD400 in a Tri-Z
    Remove all the warning label and let nature take its course
    Baltimore, MD
    6,088
    There was just someone selling a frame for the rd350 set up as a trike. Alot of companies at one time made frames for the r5\rd350\rd400. You can still find some neat parts too. DG gold heads, DG pipes, pvl ignitions, hi comp pistons, oil pump block offs, dip stick coolers and even conversion cool heads(which are rare but sometimes pop up for sale). I have a suspension frame made for the rd350. They were quite the terror at the dunes at one time. And the rd350\400 is the grandfather of the water cooled 350 stroke quad engine. You can run carb spacers, rz350 intakes and a boost bottle for a nice increase in power across the powerband too. I don't know how well they fit in a tri-z, but they definitely make for a fun trike. Good luck with your conversion.
    Sep 2005
    Lipetsk, Russia
    2,824
    Lets not forget that the RD/RZ350 and 400 are VERY similar to the Banshee engine, it's basically the same thing! And because I've seen Banshee engines in Tri-Z's, I imagine it wouldn't be too hard to shoehorn an RD400 in there as well!
    I'm back in the USSR...
    Nov 2006
    Florida
    1,663
    3Razors you got any more wicked pics of your sand dune buddies or your bike?! They look really sweet!
    Hey Cole, do it or the banshee motor That'll be a ride right there
    Jan 2004
    Palmetto,Florida
    2,300
    Iv'e done the RD250,350 and the Daytona 400 .. the 400's SCREEM !! the 250-350's are no faster than the TRI-Z,ATC 250's .. BUT...........
    the part's for the RD's are rare and Notchy Shifting... good luck
    "07" DR650 Suzuki Dual Sport
    Aug 2004
    Phoenix
    1,229
    Wish I had more pics I know I have others but they get moved around in old mags and quite a few have been tossed out by the gf.
