Results 1 to 14 of 14
Thread: Need advise on what to do: 350x fuel tank
    p26575r16's Avatar
    p26575r16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Reno NV
    252
    Finally got the X running again tonight. I put it up in march with a tank full of vp 110 octane. Needless to say, it ate the seals out of my fuel petcock and leaked everywhere. I tried to remove the petcock, but the big nut is on so tight that it is spinning the treaded part inside the tank (I have an aftermarket plastic tank). I stopped there, My question is does anyone have an idea on what to do? I don't have the money for a new tank right now and the fuel is only leaking arount the big nut (it must have came a little loose, the petcock spins now), JB weld it, or anything like that? I should also mention that the 2 allen head screws holding the whole assembly in the tank are so tight that they are stripping, trying to get them loose, and I don't what to make the problem any worse than it is. Thanks
    '86 350x
    '05 sportsman 500 (the couch)
    Sep 2006
    S.E. LA
    700
    Well, I don't think you will be able to jb weld it if it has gas leaking there. You can try drilling the small screws and tapping in a torx bit and break them loose with a ratchet.
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
    Ugggh, remind me to never leave in race gas for a long period.... What is that petcock thread pressed in or something?? Is it a Clarke or I forget what mine is but it's BIG...
    Feb 2006
    Central Florida
    1,090
    jb weld should be impermeable to fuel??
    quiet people seem intelligent
    p26575r16's Avatar
    Nov 2006
    Reno NV
    252
    I am not sure who makes the tank, it's about 3.5 gallons or bigger though. I know its about 10 years old. I am not sure if its threaded into the tank or not. I believe its just got a o ring seal that is between the base of the fitting and the tank. I cannot get the base off due to overtightening of the 2 bolts. It's not leaking there so I think I will just try to jb it for a while. I really want to make sure everything else is o.k. before I spend a ton of money on a tank. I may end up cutting the bolts off and putting a plug in it, and then make a new fitting.
    '86 350x
    Quote Originally Posted by p26575r16 View Post
    I think you have the same tank I have. The allen bolts are stripped where the allen wrench would go?? If you can't grab the head with vice grips, I'd slice them with a dremel and use an impact screwdriver.
    Don't just dump JB weld on it, it could fail when your far from home and that suks. My tank has an oring under that aluminum base.
    Lancaster, PA
    1,738
    This stuff is available at most NAPA, Auto Zone, etc and I have had excellant results with it, you should keep some on hand for emergencies anyway. You can even apply it when wet with fuel. Does not work on Diesel.
    http://www.permatex.com/products/aut...ank_Repair.htm
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Apr 2006
    Crestview, Florida
    2,429
    JB Weld wont hold up to fuel.
    Feb 2006
    Central Florida
    1,090
    Quote Originally Posted by Erics350x View Post
    http://jbweld.net/products/uses.php They sure seem to think it does.
    I use it on my fuel tanks no problem.
    Apr 2006
    Crestview, Florida
    2,429
    i've had it fall of on everyone i've put it on.
    Feb 2006
    Central Florida
    1,090
    really? I purposely make the holes bigger and push metal to the inside, clean with denatured alcohol and apply. The first round of JB will sink into the hole and grip the inside. It almost always takes two applications to get a good seal for me.
    the one I am working on now the JB will be visible under the paint. I had to dent in the leaking area so when I get the JB on I can go over it with filler instead of trying to hide it under paint.
    p26575r16's Avatar
    Nov 2006
    Reno NV
    252
    I know this is an old thread, but I have an update. I ended up temporarily sealing the leak with some of that jb weld looking putty from the parts store that states it seals even under water. All I can say is everyone should keep some of that in their toolbox. It worked very well, but it was not a permanent fix. I called clarke and found out they offer a new petcock that replaces the original assembly. The only difference is there is no reserve. I told them I was not sure if my tank was a clarke and they said if it has the two outer holes with the petcock in the middle it will work. I ended up ordering it for $16 (plus a ridiculous $8.50 shipping). I recieved it the other day and it took care of my problem. I was very impressed with that company (clarke). They were very helpfull and very nice on the phone.
    '86 350x
    Mar 2008
    EastGreenbush, newyork
    3,494
    good to know!! glad you updated. 3 yrs later!!lol!!
    sittinguy's Avatar
    sittinguy is offline Titanium Balls Arm chair racerAt the back of the pack
    Dec 2003
    343
    Take a mini hack saw and cut the nut, once the nut is cut through it should pop loose and come off.
    The OEM tanks look SO MUCH better than the plastic ones, Don't give up on you metal tank. New ones are not available as far as I know
