Thread: Big Red motor swap question
    Aug 2007
    Burlington maine
    652
    Will an XR200 motor fit into my Big Red 200E frame easily? I woul like a manual clutch.
    Luke
    1987 Honda 200X 90% way through frame up.
    1987 CR500R Motor, Soon to be a 540 ATC motor
    1986 250R frame, For now
    2008 Honda 700XX
    2004 KFX700 Torque monster!
    2011 Can-Am Commander 1000X
    Looking for misc Liquid R parts
    Northern Maine
    505
    Hey Luke......... I know what you mean about a manual clutch, I kind of prefer them myself. Goes back to my motocross days I guess. As far as using an XR engine...... the kickstarter might prove to be a problem as it swings rearward instead of forwards, like a 200x for example. Other than that I believe it might be a bolt in. How about using a 200x motor? steve
    McDerry is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Maine
    440
    How much would be involved in putting the side cover and necessary clutch as sundries to make the 200E have a clutch. Then you'd still have the low range, electric start, and pull start backup.
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by McDerry View Post
    Alot, the cranks are different, you would need to split both cases and take both cranks apart so you could use the left side of the E crank and the right side of the XR, other then that it might work. I haven't done it but I read that someone else did on their honda and I was checking into doing it with my Yamaha. A lot of work for a clutch.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
