we,,, it seems no matter what i do with anything, i CANNOT get the midrange rpm's right. it always bogs/sputters. the top end is insane, and it idles fine all day long. i think part of the problem is the needle. the needle does NOT anchor in the slide, so it can move independently of what the slide does.
i have actually had the needle pop out if the slide and act as a throttle limiter, wedging itself between the slide and the top of the carb, not letting me past like 1/8 throttle.........requiring me to tear it to pieces to put hte needle back into the slide.
so, im think im going to get a Kehin carb as soon as i get the money.
also, sometimes after riding awhile, it will just shut off, like it flooded out.
also, when just setting there, gas will randomly leak out of the overflow tubes, then stop again, when it is NOT running, setting on flat level ground.
now, the plug is black, but it still seems to run hot. it runs around 330 degrees plus.........which in all my motor experience is WAY TOO HOT i think?
and it all of a sudden started "kicking back"
almost EVERY TIME i kick it, the kicker ROCKETS back the other way(or tries to)
it REALLY HURTS. before today (riding about 4 hours) it RARELY did this....now it does it almost EVERY KICK.
so, my questions are:
1. what should be a good operating temp range for this motor?
2. Why would the kicker start kicking back all-a sudden?
3. How to set timing on the thing? perfect is not needed, but something close, after it gets real hot, it seems to make a knock occasionally, but only one knock.
4. What should i check for this bogging/sputering? tried every needle clip, nothing really seems to make it better. top end seems OK.
still have no idea what is causing it to kick back. could it be the timing i wonder?
the throttle...midrange is nonexistent.
