Page 6 of 8 FirstFirst ... 4 5 6 7 8 LastLast
Results 76 to 90 of 117
Thread: Yamaha
  1. #76
    Sep 2007
    West Richland Washington
    430
    Like remember where everything goes ?
    YTM Boy's Mini Me. Duhhhh
    Do not try to help me, unless you like waisting your time.
    -James9r9r
  2. #77
    Sep 2006
    N.S. canada
    499
    get a clen bench and lay all the parts out in steps or label everything
    86-tecate
  3. #78
    Sep 2006
    N.S. canada
    499
    if you do this seriously and take our advice we will help you its just up to you man
    there is hope for that trike
    86-tecate
  4. #79
    Sep 2007
    430
    Well Do you know how many bolts I will have to take out and will I have to take the tires off to get the motor out ?
    -James9r9r
  5. #80
    Sep 2005
    Lipetsk, Russia
    2,824
    If you're going to be stripping down the engine, you should make drawings of what goes where, clean all the parts/bolts and put them into different foam cups labeled where they go.
    I doubt you'll have to remove tires to get to the engine mounts, but the rear engine mount bolt might be easier to take out if you pull the wheel off on the side it slides out to (opposite side of the nut).
    To pull the top end off the engine, you're looking at 4 to 6 bolts that need to be loosened, and then the whole top end should just slide off. BE SURE TO DO THE PB BLASTER TRICK BEFORE YOU TAKE THE CYLINDER/HEAD OFF, if the engine is still seized you won't be able to pull the cylinder off anyhow (piston will be stuck to the cylinder and not let it come off).
    PLEASE PLEASE PLEASE TRY TO FOLLOW DIRECTIONS MAN. I am seriously begging you. Don't act like a douche, you're really beginning to annoy lots of people over here, and if you continue, you'll just get kicked off the site and ruin your trikes, and then you won't have anything to ride until your parents get you something. So just pay attention and be quiet for a little while, and ask INTELLIGENT questions if you have to. Don't be an idiot and ignore us, or people will stop helping you.
    I'm back in the USSR...
  6. #81
    Feb 2006
    Central Florida
    1,090
    Quote Originally Posted by james9r9r View Post
    yes, the tires MUST come off the rims before you can get the "motor" out.
    There will be a total of 26 bolts that you will have to remove.
    If there is anyone here that believes that you are capable of removing the engine from the frame and/or removing the top end to see what is wrong; I would be surprised.
    quiet people seem intelligent
  7. #82
    Quote Originally Posted by rally4x4racer View Post
    Rally, I thought we were gonna give this kid a break?? Whats up?
    We BOTH know that only the left tire has to come off, why make him do anymore work than necessary??
    And as far as the bolts go, yep there are about 26 that have to come out but it's easier just to cut the frame for the lower cradle bolts, I think there are 6 of them.
    EDIT - WHERE IS THAT MANUAL NOW JAMES!! READ IT!!
  8. #83
    Feb 2006
    Central Florida
    1,090
    I did not want to make it sound too complicated so I generalized and summarized
    things a bit...
    I will be more accurate next time, and I will take my tourettes meds
  9. #84
    storm_impulse is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2007
    west virginia
    291
    i have faith that james can do it. if he listens to everything that everyone says and reads his manual there shouldnt be any complications no? james apply some common sence when tearing it apart or putting it back together for that matter.
    good luck
    1986 atc 250R. needing alot of parts. winter projet!
    1988 lt 250r quadracer. building now.
  10. #85
    Sep 2007
    430
    Well I just hope theres not so much damage done its not worth rebuilding.
    -James9r9r
  11. #86
    Sep 2007
    430
    It goes into gear good but when I try to put a screw driver in the flywheel/rotor and turn it it will not budge.
    -James9r9r
  12. #87
    Sep 2007
    430
    There are really 26 bolts ????????????????
    -James9r9r
  13. #88
    Sep 2007
    west virginia
    291
    dude there prolly is 26 bolts. u asked and they told. now go take them 26 bolts off!!!!!!!
  14. #89
    Sep 2007
    430
    Where should I start ? Like with the wiring ?
    -James9r9r
  15. #90
    Sep 2007
    west virginia
    291
    disconnect all wiring,cables, gas lines from the motor. then begin to take the motor off the frame by removing the 26 bolts everyone has talked about.
