Okay so my mach is running mint now, and just when i think everything is fixed, my lights die, and all of my guages dont work except the speedo, and my heated grips dont work. It did this last year too but somehow it just fixed itself. Any ideas?
1984 Honda 250R
*Still Under Construction*
Wiseco .20 Over
Stainless bolt kit
Fresh Bearings
Everything in the process of repainting
DG National Pipe
Boyeson Power Reeds
Ported & Polished
Gripper Seat
Uni Airfilter
Still Much more to do, so much for just needing a top end, axle bearings, and airfilter.
Probably a loose contact. Check all your plugs, wires, etc and make sure your ground wires are all attached tightly. Either that or the regulator just died.
I'm back in the USSR...
the CK3 chassis had a wire harness problems .
1987 200x
1987 Big Red
1986 250R
1986 Tecate
1986 Tri-Z 250
1986 Big Red
1985 Polaris Scrambler
1985 KLT 160
1985 Tiger 250
1985 Big Red
1985 Big Red
1985 250sx
1985 70
1985 225 DX
1982 185s
1983 110{Red}
1983 110{Blue}
(2) 1977 ATC 90
1971 US90 Red
1971 US90 Parrot Green
1971 US90 Blue
Its a 96 so its a F2000 chassis, but ill check all of the plugs, and ground. Im sure after 11 years and a few thousand miles something got loose.
1984 Honda 250R
Wiseco .20 Over
Stainless bolt kit
Fresh Bearings
DG National Pipe
Boyeson Power Reeds
Ported & Polished
Gripper Seat
Uni Airfilter
prolly a ground
I singled it out to a red wire which appears to be a ground, it comes off of the wires that are taped together which go from the switches, to the guages.
1984 Honda 250R
Wiseco .20 Over
Stainless bolt kit
Fresh Bearings
DG National Pipe
Boyeson Power Reeds
Ported & Polished
Gripper Seat
Uni Airfilter
