Thread: Warrior shock on the Tri-z
    Sep 2003
    Brookville,PA
    1,408
    Searched it, couldn't find exact years. Will all warrior rear shocks fit the Tri-z? If not all, from what year to what year will? Is it a direct bolt on?
    they all will.. yes direct bolt on and go.. you will have to do something with the rezzi tho..pice of rubber and a hose clamp .. or use the warrior rezzie mount and bolt it to the pan,
    Attached Thumbnails Attached Thumbnails 100_2273.JPG   102_3538.JPG   tri z 009.jpg
    HEAD09's Avatar
    HEAD09 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    NH
    433
    did you notice a big difference from the stock shock? better or worst
    na
    5,702
    I have a stock Z shock on my 85 1/2,and a 2002 warrior shock on my Mx Z.
    The warrior shock is stiffer.At least between my 2 bikes it is.
    Ride height is the same.
    Proudly NOT a member of
    "Team on the Teat"
    Ashland City, TN
    2,576
    Banshee piggyback res. shock will work too, but you have to get rid of the stock gas tank.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Sep 2003
    Brookville,PA
    1,408
    I picked up a Warrior shock off of Ebay, It show up today. Works great fits just like it was made for the Tri-z. Would highly recommend this route if you need a shock for your Tri-z. It is also probably the cheapest. Thanks for all of the help and input everyone.
