You making a database out of this?
GO FOR IT! excelent idea
Dont bother, Ill just serch/post and find my info when needed
quiet people seem intelligent
there's 1 for tri-z's allready look up tri-z brian
NO 3 WHEELERS CURRENTLY SOLD THEM ALL![]()
02 GSXR 240 kit STRECHED
03 BANSHEE 421 CUB
07 LTR 450
08 RZR
05 f7
07 KLX 110
670 ho skidoo powered banshee
1985 nacs kx 80 race quad
Thanks BP, Thats one i didn't know, AND can use on a current project!. and yes, I havent decided on an exact format yet, but it will either be a database document, or something done in pagemaker and converted to a pdf. either way it will be hosted on my website for everyone, as long as the d/l's dont eat up all my bandwidth.
1985 Honda 250es "Big Red" 1984 Honda 200s (Sold)
1984 Honda 125m 1986 Honda 200x (new project)
2003 Raptor 660 1978 Suzuki GS1000
I found that on air filters as well old skool
250ex, 350x and 86/87 after market airfilter... All interchange...
www.3wheeler.org
* * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
04-05 450r swingarms, bolt up with slight mods.to 250rs .I think it's just shaving a bit off here and there
Name of recieving and doner's MAKE, MODEL, & YEAR/YEARS
early 90's XR200 to 83-85 200x
-Name of the part
Carburetor 30mm
-Vender, if applicable for aftermarket (things like exhausts) factory or aftermarket Keihen (mine was Chinese)
-Direct swap, or slight mods..(I know all parts can be made to work with "some mods.") Id like to limit this reference to minimal work such as adding extra washers, small amounts of grinding/sanding/clearancing, things of that nature. Also, if it is a "slight mod," please briefly describe your mod.
Will bolt up and seal to factory 200x intake, however the early 90's XR200 intake will fit better. Will also need to warm up the factory breather tube with a heat gun to get it to fit the new carb. Also, (obviously) will have to tune it to your bike.
-PLEASE MAKE SURE YOU KNOW YOUR SWAP WORKS! Indicate if this is something you have successfully done yourself, have personaly seen on another's trike, equivalent part numbers, or whatever confirmation you may have.
I have done this myself. some info found on 3ww forums..
-Indicate parts number (and source of parts number such as Honda, Manufacturer, Dennis Kirk) If it is needed.
found on ebay (XR200 carb) Chinese knockoff was $60 shipped in 11/07
awesome idea! I always wished that there was something like this. My friend owns an auto salvage yard and he has some books that he can look up stuff like this for cars. I always thought there should be something like this for the bikes and atc atv etc. Maybe there is already, because there are a lot of motorcycle salvage yards out there. I don't know but worth looking into for sure.
My Youtube Channel:
http://www.youtube.com/profile?user=ditchmudrich#g/u
My Feedback:
http://www.3wheelerworld.com/showthr...k+for+ditchmud
Trike Circus is May 31,2014
1985 / 86 350X
-Name of the part
Rear Bearing Carrier
-Vender, if applicable for aftermarket (things like exhausts) Rad and all others
As long as you go with the 1986 rear sprocket set-up - a 250X / 300EX rear Bearing Carrier will directly fit in your 350X Swinger Housing. 1986 is a direct bolt on - 1985 requires the 1986 rear sprocket, as the sprocket bolts are recessed into the sprocket - the 1985 will have bolt clearance issues with the Bearing carrier.
I have done this to my 1985 350X
Ebay - All Day Baby!![]()
sweet guys, im getting a lot of good stuff here. keep it coming.
Yamaha Ytm-200e shaft yamahauler
-Name of the part
rear axle final drive
The gears inside the final drive of the yamahauler can be interchanged with theses from the ytm-225 final drive ( note that the gearing will be 15% higher)
You will need to use the ytm-225 final drive housing and bolt it onto your 200e bearing carrier. The only other parts that need to be changed is the big left-hand nut that keep the pinion shaft in place, use the 200e one on the 225 housing.( the 225 one is longer and won't let the middle shaft slip into the housing)
I have done this to my 1984 ytm-200e. Yamahauler here on the board helped me with this repair.
Parts are available are your local salvage yard
1984 Yamaha YTM-225DX![]()
Québec 3-wheeler riders group
atctim.
350x should not accecpt a trx250R bearing carrier, they interchange with a 400ex and are wider and bigger diameter i was told buy the guy who made my swingarm. double check that...
350x should only be able to use trx250x and trx300ex
A 250X or 300EX engine is a direct bolt in on a 350X frame. The only mod needed is the exhaust which is very simple, of course if you use the 300EX you need to fab up a box for the battery. Have done it myself and rode it for years.
Tionesta Trikes ATC 450R
86 250R
86 Tecate-3
83 ATC 70
85 Big Red
81 KLT 200
85 250SX
Verified!
Also
84/85 tecate PETCOCK (recieving) (do not know off top of head if 86/87 petcock same as earlier years)
03/04 Kawaski Bayou Petcock (donor)
DIRECT SWAP
Put it on my 85 tecate
Dont know PArt#'s off the top of my head sorry..
www.3wheeler.org
Just to clarify, and make it a little easier, I don't really need part numbers or venders or the like, unless you are using that as verification that the swap works, or, if your sure only one aftermarket company's product will work such as, a supertrapp from model X is a direct bolt on to model Y, but a DG will need some mods. Thanks for all the info, and for being so thorough. I'm going to try to post up a VERY incomplete version of this by next weekend so you guys can look at the format and give me some feedback.
