Results 1 to 15 of 15
Thread: need input on .223 and 22-250
    leroy,ny
    245
    I am looking at getting one of these guns and need some input how much range can I get out of a .223 and how much with a 22-250? I like the .220 swift but I cant find one.
    Oct 2007
    Grosse Tete, LA
    3,441
    we have the .22-250 in a remington target rifle with a 32x scope on it. range wise, it'll go. we have it sited in at 200 and it shoots pretty much flat out to 300 or so, then you'll start seeing drop. but we have shot out to 750 with it.
    have the .223 in the ruger mini-14 it's a fun little gun. 20 round clip and it'll rip em off as fast as you can pull it. also a flat shooter though it isn't really in the same league with the .22-250
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    22.250 hands down.
    Feb 2006
    north of buffalo
    557
    .223 are cheaper than 22-250 to shoot last i looked. I have a .223 i like it, i don't have a good scope on it yet. Both will reach out there. From what i've read and seen those 2 are the choice for coyote hunters, unless you run with dogs and then it's shotgun.
    Runners:
    84 200s
    05 rancher
    12 rancher
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    I love the 220 Swift.
    4,000 fps out of the muzzle is what i'm talking about.
    MyMistress86R's Avatar
    MyMistress86R is offline HEY! I don't really like your attitude right now! Arm chair racerJust too addicted
    Jun 2004
    Ohio
    1,026
    I would have to agree with the majority and say that the 22-250 is the better of the two once 300 meters is reached. I spent 12 years in the military and became very comfortable with my M-16 (.223) and my father has a Remington 22-250 that he uses for "varmiting". The .223 will start to fall off faster at range while the 22-250 has a longer reach and is much easier to control at distance. Funny fact...due to the muzzle velocity of the 22-250, the 22 caliber round will actually swell to the size of a .44 within roughly 100ft of leaving the barrel!!
    Official Wellsville soil tester! With pics and a $3000 medical bill to prove it...
    1986 TRX250R
    ESR 310~trail ported w/ torque exhaust flange~36mm Keihin carb~v-Force3 reeds~Pro Circuit Exhaust~custom 16oz flywheel weight~2006 YFZ front shocks~adjustable rear dogbone~fully functional rear brake light~Durablue +4 axle
    Former Ride 1986 ATC250R
    Oct 2007
    Grosse Tete, LA
    3,441
    just kidding...i did not know that about the swelling. knew there was a a little but DAMN!
    that explains why those little killdeers explode when they stray a little too close to my target. that or the plastic insert ballistic tips.
    Jun 2004
    Ohio
    1,026
    LOL Goat...yeah, it's pretty wild. Just take a few shots at some 1/4" ~ 3/8" plate steel from about 300 yards and then check the size of the holes.
    One of my favorite tricks for friends is a gallon milk jug filled with water at about 200 yards. I have yet to find a cap!!
    1986 TRX250R
    Mar 2005
    overton, PA
    5,257
    yeah i use a 22-250 for doe season. its a great flatsahotign guna nd have reached out already 600+yeard swith acuracy. i am shootign groups the size of a shotglass at 300yards. its a great cartige but for sheer take down and brush hunting cant beat my 45-70
    iowarotax's Avatar
    iowarotax is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2006
    iowa
    393
    I shoot alot of coyote and fox each year. I carry both calibers in my truck. If I am going to have a long shot, I grab the 250. But my normal gun is a Bushmaster Varminter .223. Its very accurate out to 300-350. The 250 is alot flatter, but really tears the fur up. I dropped a coyote at 475 yards on the run 2 years ago. LUCKY shot!! Overall the. 223 is cheaper to shoot and a good fur gun.
    198? 250 Tiger 198? 200 Tiger 198? Tiger 500 1985 KTM 500 1985 Can-Am mx-lc 250 1988 ATK406
    nate b is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central WI
    433
    Funny fact...due to the muzzle velocity of the 22-250, the 22 caliber round will actually swell to the size of a .44 within roughly 100ft of leaving the barrel!![/QUOTE]
    Are you using rubber bullets?
    85 atc 250r;
    PSI porting & head mods
    fmf pipe & silencer
    boysen rad valve & reeds
    38mm air stryker
    Jun 2004
    Ohio
    1,026
    Nate ~ Nope...that's a plain-jane copper jacketed lead round.
    1986 TRX250R
    Oct 2007
    Grosse Tete, LA
    3,441
    here's another trick for you...1 can of starting fluid, 1 small fire, one very great distance away. fire a shot and watch the show.
    that or my personal favorite, gallon of gas, light the top, stand back about 40 feet, blast it with a shotgun.
    but to get back on topic, come january, i'm thinking about buying the new TAVOR rifle. if i can find one legal...hell yes. if not...sneaky sneaky. ha
    Central WI
    433
    thats wierd, wonder why you dont see large diameter holes when you shoot a paper target? how big of a hole should I be seeing with my 7mm STW? 1/2 inch. how bout a 30-378 weatherby, 3/4". Its called expansion, on impact!
    back to the original question, all 3 are good rounds, personally I don't like the .223 and think its a round that should have never been made. ammo is cheaper for a .223. Barrel life might be shorter on a .220. Definatly cant go wrong with a 22-250.
    85 atc 250r;
    fmf pipe & silencer
    38mm air stryker
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Quote Originally Posted by nate b View Post
    Do you know what a progressive rate twist is?
    And what rifle has this"progressive rate twist"????
    What "round" holds the worlds most accurate round within 300Yards?
    What is a 17 Mach Cheeta?
    What round holds the record for most accurate handgun?
    Just some fun facts!
