Thread: 200x clutch nut?
    Jul 2006
    galway ny.
    534
    200x clutch nut?
    anybody have a idea of how to get that nut off of the clutch without it turning?and the other nut on the side thing to.advice would be much appreciated.i broke a spring holder off already lucky i have another motor to take one off of but still its a pain in the you no what.want to ride in the snow this weekend if i can get the x back together.
    85 tecate 86lt250r
    85atc 200x
    oldred95 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2006
    OK
    196
    If I'm understanding you correctly this is the part where you get your impact out and zip the nut right off. Jamming things into the gears doesn't sound like the best thing for the gears.
    1984 200X bored .040 over, mild port work, K&N filter
    Planning on custom exhaust, XR200 carb and cam
    Nov 2006
    Tulare, California
    719
    The way I have done a 200x and 350x clutch is put a screw driver in the rear sprocket against the swingarm and break it loose. Same with torqueing it. Doesn't seem to hurt anything.
    Current Bike:
    1985 Honda 350X
    Bikes owned:
    1984 Honda 200X
    1982 Honda 250R
    1985 Honda 350X x3
    1985 Honda 250R x2
    1985 Honda 500X
    Tionesta, PA
    5,747
    As John said - a penny in the gears works - but use it with an impact gun - makes it really easy - double check - but I am 99% sure it is left handed threads for that nut - FYI.........
    The soft copper penny will not damage any of the gears.
    Minnesota
    451
    I wouldnt worry about the penny messing up the gears, Id be worried about jamming something in there and causing extra stress on the bearings / shaft. But with an impact, it might not be to bad. Ive always been able to get them off by just holding the basket with my hand and a good impact. Ive also learned not to put screwdrivers between the spring posts on the pressure plate. Thats never good news.
    EDIT: i know your on a 85, but 86-87 is not left hand threads. Also, My manual shows a tool from Honda which is plate with 4 holes which bolts to the spring mounts, a hole threw the center for a socket, and about a 12-18" handle welded on. That shouldn't be to hard to make and would in my opinion be the "right" way to do it.
    1985 Honda 250es "Big Red" 1984 Honda 200s (Sold)
    1984 Honda 125m 1986 Honda 200x (new project)
    2003 Raptor 660 1978 Suzuki GS1000
