Thread: polaris prop shaft question
    ovhonda1's Avatar
    ovhonda1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2005
    Louisville, KY
    369
    Anybody know if the front prop shaft on a polaris scramler 500 can be bent back in to shape? Mine has a small bend in it. It still works but is rubbing and making a popping noise. The entire assemble will run me about 225. Trying to avoid this.
    Missouri
    99
    I dont see why not, If you have a press. Seeing how its already bent you cant relly hurt it.
    Proud owner of a "cornfed" polaris 500 scrambler. . . 4X4
    Coming soon Ninja/mojave/dune buggy, three wheeler
    Visit www.tecateconnection.com for tecate info and to find out whats going on in the tecate world!
    Aug 2004
    Ab Canada
    4,368
    You might be able to true it back up with a press and some v blocks.....better be perfect tho or you will prematurely fry Yokes and bearings, not that you arnt allredy with it being bent,,, What did you hit a tree n bend the frame or something?
    1985 Tri-Z-
    ovhonda1's Avatar
    Sep 2005
    Louisville, KY
    369
    I don't know what happened. I bought the thing and a couple of months ago for the GFriend and it was fine. Haven't really ridden much. Rode around in the yard a couple of weeks back and started making popping noises. After searching, I found that it is hitting the frame becasue the shaft is bent. No wrecks at all. I'm puzzled. MUst have been bent already and eventually gave way enough to where I can hear it? Hoping that the ujoints aren't bad yet. Going to take it apart this weekend.
    the U joint might be shot allowing it to slide over, giving the appearance that its bent. popping, crunching, clicking.. sounds like the joint is shot..it would take alot to bend that short shaft
    also check and see if the bolts for the front diff are loose.. letting the the diff get cocked and put stress on the U joint
    inspect all the round hocky puck motor mounts too
