ignition switch
help! I am trying to find out what wires to short out to get my bike to be continuously "on". There are 4 wires coming out of the back of the switch - red, black, green, yellow. someone help! my keys are out of my reach until next week and i want to test out the new carb i put in!!! thanks!!!!!
Green and yellow affect lights, I believe. Tie the red and black together and see if you get spark.
I'm back in the USSR...
i pulled out my trusty clymer manual and looked at the wiring diagram. on an 84, off is when black and green are connected. on is when red and yellow are connected. so i just disconnected the black and green from the ignition switch(which is in the off position), then attached the red and yellow together. they even made it easy to hotwire. all the wires were female except the yellow, which was male. so just disconnect all wires from ignition switch, then plug the yellow into the red - done!
The two larger wires are for running the regulator on the charging system. YOu short them to start the regulator and power up the vehicles lights and charging system. Put these on a switch so as to not discharge your battery when the bike isn't running.
//ArrowChat Integreation Code
