Results 1 to 11 of 11
Thread: LT250R rear shock
    Sep 2006
    Shreveport, Louisiana
    888
    LT250R rear shock
    I need a rear shock for my '88 Quadracer 250 and am unwilling to put out for a new Works or Elka or Fox or something like that. You can find new take-offs on ebay from various new sport quads that all look pretty much the same and they all have a key difference from my stock rear shock...they use a link on the swinger which makes the lower mount different, see pick below. The shock pictured below is typical of those off new sport quads, it has a regular eye on top and a bracket-like bottom mount to fit the link on the swinger. I was wondering if anyone had ever adapted one of these to use in place of a shock that needed a regular eye on the bottom? I was thinking I might try it with a heavy rubber bushing between the gap on the bracket and mount the bottom bolt through the shock and bushing. Don't know if it will work, but I'd like to try it. I'm looking at something like a LTR450 or YFZ450 rear shock, the TRX450R rear resevoir doesn't look like it will fit, I think the horizontal resevoir won't fit in the space I have.
    The rear shock on a Raptor 660 looks like it will work and has regular eyes on top and bottom, how good are these rear shocks?
    I wanted one with a resevoir and some adjustability cause I'm gonna XC race this quad...on the cheap if I can.
    Thanks, Chris
    >>>>>>>>>>>>>>>2007 Yamaha Raptor 700R>>>Cross Country Racer<<<<<<<<<<<<<<
    www.myspace.com/bluelionracing
    Support my 2009 sponsor:
    For all your ATV suspension needs.
    okieRrider's Avatar
    okieRrider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2003
    344
    Check out polaris rear shocks, was gonna post an ebay link of one but remembered the rules...lol anyways The polaris rear shocks are mostly built by fox. Look up the polaris predator, the 400 scrambler, and 500 scrambler.
    Hold my beer and watch this!!!!!
    <a href="http://www.sponsorhouse.com/Members/miniracer94/?from=1" _fcksavedurl="http://www.sponsorhouse.com/Members/miniracer94/?from=1" alt="" ><img src="http://www.sponsorhouse.com/Assets/Promote/athletes/b225x30.gif" _fcksavedurl="http://www.sponsorhouse.com/Assets/Promote/athletes/b225x30.gif" alt="View Destin Sanders's Profile" border="0" /></a>
    Sep 2006
    888
    Thanks Chris, that's a good idea, I'll check it out.
    Nov 2006
    southern oregon
    2,338
    The factory shock is actually pretty good... If you get one rebuilt and revalved for your weight it should be more than adequate...
    2-stroke lover
    Newfoundland
    5,280
    I've got a remote res Rap 660 shock here that has been rebuilt and no ride time. PM me.
    Aug 2006
    huntington, ny
    192
    i am looking for some shock swaps for my 85 lt 250r too will the 660 shock bolt in?
    Sep 2006
    888
    IDK. Are the 85 and 88 the same? Lots of things are different between these two models.
    Jul 2006
    galway ny.
    534
    my 86 back shock was rebuilt and it handles great i way 210 and it dont bottom out at all i have works up front so it rides good and handle good air jumps.
    85 tecate 86lt250r
    85atc 200x
    Sep 2006
    888
    I picked up a pair of '07 LT450R front take-offs. Only had about 6 hours on them and the guy says they are really good. I figure anything new is way better than the old stuff on it now. On ebay I won a rebuilt stock shock. Hopefully I will be pretty good on suspension now, I just hope the rebuilt rear is set-up for someone close to my 240 lbs.
    Hey digity, I noticed that you and I have nearly the same rides. You and I should swap notes one day about lessons learned from our machines. I gotta ask though, which one is faster the Tecate or the Quadracer? I know my Tecate is faster, and probably handles better too, but lots of time and money have been thrown at it to get it that way. Chris
    Aug 2004
    Ab Canada
    4,368
    Rebulding a stock shock is cheap n easy, just get a seal kit, take it to a shop and have them fill it with oil n set the piston height+ fill with nitrogen, it takes all of 20 mins.
    1985 Tri-Z-
    Jul 2006
    galway ny.
    534
    the t3 no doubt is faster but not by much my quadracer is fast enough thou a great machine for its year.i put alot of money and time in it to handle like it does got to love them 2 strokes.
    85 tecate 86lt250r
    85atc 200x
