Thread: Bottom end bearings for 81-84 250r?
    Aug 2006
    NW Ohio
    1,043
    Does anyone sell a complete bearing and seal kit to rebuild the bottom end of the 81-84 250r's?
    ATC500AF
    Aug 2006
    NW Ohio
    1,043
    anybody know?
    ATC500AF
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    u mean crank bearings and seals? the rod bearing would be in a rodkit.
    the crank bearings and seals can be had for about 35 on ebay from a seller racergirlsrock or some shorthand version of this name
    Aug 2006
    NW Ohio
    1,043
    no i mean EVERY bearing and seal in the bottom end
    ATC500AF
    May 2007
    Massachusetts
    36
    no, i havent found one yet, you can find one for the 78-80 CR250 Elsinore which i beleive is the same motor, minus a counterbalancer
    1984 Honda 250R
    *Still Under Construction*
    Wiseco .20 Over
    Stainless bolt kit
    Fresh Bearings
    Everything in the process of repainting
    DG National Pipe
    Boyeson Power Reeds
    Ported & Polished
    Gripper Seat
    Uni Airfilter
    Still Much more to do, so much for just needing a top end, axle bearings, and airfilter.
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    hmm. they have them for the 85-86 R. not sure on the 84?
