Results 1 to 15 of 20
Thread: Theory correct?
    Sep 2007
    California, USA about 50 miles north of sacremento
    976
    Theory correct?
    Please excuse the paint picture but here is what I am thinking.
    My air box pulls air from the top of the box. While this is good it still makes the carb have to pull air in. If you where to create a custom air cleaner unit that is pointing towards the front of the engine, wouldn't that give it more power? Thats why people put CAI's on their cars.. Does this principal apply correctly?
    Oct 2007
    Grosse Tete, LA
    3,440
    my typhoon intake on my car doesn't point anywhere near the front of the engine...it's inside my bumper actually.
    Perth, Western Australia ( The most isolated city in the world!)
    55
    Just like on aTri Z by the look of that sketch
    My Rides-
    1985 Yamaha YTZ 250 Tri Z
    another 1985 Yamaha YTZ 250 Tri Z
    1985 Honda ATC 200 ES Super Red
    1975 Bultaco Pursang 250 ( Hey I know it's only got two wheels)
    It's not an optical illusion, it just looks like it.
    MyMistress86R's Avatar
    MyMistress86R is offline HEY! I don't really like your attitude right now! Arm chair racerJust too addicted
    Jun 2004
    Ohio
    1,026
    I believe your are confusing the concept of a "cold air intake" with that of a "ram air intake".
    The design principal behind the CAI is to simply get the intake air source away from the heat of the engine. Most automotive kits relocate the filter to an internal fender area or down into the leading nose area of the car.
    In comparison, the RAI is designed to straighten the intake path and create as unobstructed a path as possible from the front of the vehicle to take advantage of the oncoming air as the vehicle accelerates.
    Official Wellsville soil tester! With pics and a $3000 medical bill to prove it...
    1986 TRX250R
    ESR 310~trail ported w/ torque exhaust flange~36mm Keihin carb~v-Force3 reeds~Pro Circuit Exhaust~custom 16oz flywheel weight~2006 YFZ front shocks~adjustable rear dogbone~fully functional rear brake light~Durablue +4 axle
    Former Ride 1986 ATC250R
    Sep 2005
    Lipetsk, Russia
    2,824
    I've used ram-air induction with varying degrees of success on snowmobiles before. On a Puma 340, I once stuck a 440 engine into it. The engine would bump the headlight inside the housing and vibrate it to death, so I trashed the headlight and made a funnel out of steel plating, then ran a vacuum cleaner hose down from it to the carb mouth. Stuck the funnel in the headlight housing, it ended up looking like an induction hood scoop on a muscle car .
    It worked, but only noticeable after you got the sled above 50 mph or so. Otherwise there's just not enough air being pushed in to make a difference (not enough pressure building up to make "boost")
    Unless you're making some sort of sick drag trike that will go 70+ mph in a straight line and not see much dirt, I doubt it's worth the hassle.
    I'm back in the USSR...
    Apr 2006
    Crestview, Florida
    2,429
    the bent you have to make would do more harm than good.
    Sep 2007
    976
    Ok how about this. Remove Air box and run direct to carb. Add a computer fan just behind filter and help push/pull air though susyem.
    Fan imaeg for those who don't work on comps.
    new diagram.
    Jun 2004
    Ohio
    1,026
    Not enough volume of air can be supplied by that fan. It would be more restrictive than beneficial.
    1986 TRX250R
    Sep 2005
    Lipetsk, Russia
    2,824
    I agree. Maybe if you found some industrial grade fan that could move more than 1 cubic foot of air every 30 seconds...
    Jun 2004
    Ohio
    1,026
    All in all, you are simply trying to redesign something that works just fine as it is and will not benefit you enough to waste the time and effort it would take to pull it off. Besides...if you do design such a system, you will force the motor into a lean state unless you also spend some time on jetting to balance out the intake air.
    Just not worth the effort...IMO
    1986 TRX250R
    Sep 2007
    976
    Quote Originally Posted by RedRider_AK View Post
    This moves 63.7CFM and it's $12 bucks. Gonna buy one now for my comps case ..lol http://www.directron.com/sff21f.html
    My next question would be if that would increase the flow of air to carb or limit it. So I guess I need to know what the stock flow of air would be to the carb. Anybody know that?
    Jun 2004
    Ohio
    1,026
    Again...redesigning a concept which will yield little or no potential.
    The airflow of the carb is variable based on the throttle position. The more you push the throttle, the further the slide opens, the more air and fuel are delivered. Just like any other demand based induction system. The intake stroke of the motor (2 or 4 stroke) creates a vacuum designed to pull the necessary amount of air into the chamber. If the motor needs less air than your little fan supplies, you will be instantly lean...if it needs more air, you will be instantly rich. There will only ever be (if ever) one point from idle to WOT that your fan will ideally match the necessary air needs of the motor and that point will only last for the portion of a second that it takes to climb past it or drop past it in the RPM range.
    1986 TRX250R
    Sep 2007
    976
    Hmm, did not think of it that way. I will do some thinking on that one. Thanks for the info.
    Sep 2005
    Lipetsk, Russia
    2,824
    Hey MyMistress, what about having a fan setup with a pot (like a volume control on a guitar, etc) that makes the fan spin faster when you give it more gas?
    Jun 2004
    Ohio
    1,026
    Uh well...
    I would tend to lean more towards an automatically variable resistance module that you could run off the stator. Think Throttle Position Sensor. That way, it could all be controlled by the motor itself per demand.
    Then again, whole lotta work for negligible gain. Why go to all that trouble to create a system that would just get in the way of what already works as good as it needs to?
    There's a reason cars have Ram Air and Cold Air option kits and ATVs don't.
    1986 TRX250R
