I have a 1982 ATC 110 with an electrical bug I can't fix. It will start and run perfectly for a couple hours then die and not restart for weeks.
I have replaced the CDI, stator, pulse generator, coil, wire, cap, plug and repaired a defect in the wiring where all the ground wires meet. I am getting 12 volts into the CDI and 12 volts out the black wire to the kill switch. There is no voltage coming out of the CDI to the coil and nothing to the pulse generator. All the components and the wiring ohms out ok.
The CDI box was replaced before I found the ground fault, is it possible it has gone bad? This is a really nice little machine and I hate to push it off a cliff. Any ideas?
