Results 1 to 11 of 11
Thread: Jetting The Carb
    Apr 2003
    546
    Jetting The Carb
    i am trying to get my 250r to run smooth on the low end ...i do alot of trail riding and it seems the only time it runs smooth is when i get the r's up......can anyone help me?......how can i tell what size jet is in it?...what size jet do i need to run smoother at low rpm's??
    atc86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    bangahore, mi
    306
    pull the plug out and let us know what it looks like. while your doing that put in a new plug and run it for awhile then remove that plug and let us know what it looks like. a compression test would help.
    I want a race honda with reverse.
    Apr 2003
    546
    carb
    plug is black..kinda shiney...after 1 tank...i have been trying to lean it out a bit ....a little at a time.....
    1985 ATC 250R
    2006 TRX450ER
    RIDE RED...IS THERE ANYTHING ELSE??????????
    Ashland City, TN
    2,576
    Well part of the problem is 2-strokes don't generally like trail riding in low RPM's. 2-strokes are high rpm engines, and they're meant to be run like that....if you want to putt around in the woods, get a 250sx or something.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Apr 2003
    546
    carb
    hows about you buy me one?? 8) 8)
    1985 ATC 250R
    2006 TRX450ER
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,248
    a properly jetted 250r will not foul plugs even at putt around trail speed... it takes alot of expierence to keep a two stroke dialed in ,,, i have a 4 year old plug in my 250 and trail ride all the time ,,, here is a jetting chart when you ride try to figure what throttle position needs a change being smooth on the throttle wil help when you figure it out make the nessesary changes and try it again
    Clarks Summit PA
    1,236
    also you asked what size jet you have... probaly a stocker, just loosen up the big bolt on the bottom of the carb, w the fuel shut off on off, and then grab a small socket, like a 1/4 or around there, and loosen that jet up and pull it out.. you can read a number on it,.. prob anywhere from a 138-160...what mods you got? pipe? filter? porting? bore?
    Ride it like you stole it! And never look back! They are too far behind to see!
    bangahore, mi
    306
    jet takes 6mm big one on bottom of bowl takes 17mm
    Apr 2003
    546
    carb
    no mods
    1985 ATC 250R
    2006 TRX450ER
    KASEY's Avatar
    4,248
    my 86 is all stock it has a 150 main and a 42 pilot jet, thats at 500' above sealevel,,,,
    my 85 with a few mods 38 mm carb has a 170 main and a 52 pilot
    Rittman, Ohio
    6,276
    Quote Originally Posted by SSJ3Goku
    This is right, but here is what you can do to get around it.
    First, dont touch your main jet if your plugs look good under hi rev riding. Drop the needle down to the lowest setting (mode clip up to highest notch). This will lean you out at low to mid throttle, and have no effect on top end. If you try to lean it out with the main jet, you run the risk of a meltdown when or if you do any open riding.
    Second get a smaller front sprocket and drop the gearing way down. If you go with an 11T youll be able to putt along at walking speed without slipping the clutch, and youll be cruising slow trail speeds at half throttle or better which will make your two stroke very happy. Two strokes just need to keep the RPMs up, which does NOT translate into riding FAST. Whne you are teaching a child to ride a mini, and can go all day without fouling a plug, you know you are geared low enough! Im geared 11/43 on my TRX250R, and still rarely hit 6th gear on the MX track. I see little value is gearing to do 75MPH on a trail machine, especially when you have to slip the clutch and idle the motor all day.
