Results 16 to 30 of 32
Thread: My ATC 200E repair thread. Now running and rolling!!!!!
    Pa.'s Highest City
    8,058
    huh? I didn't realize the front sprockets were diffrent like that. I was thinking just a plain old ordinary sprocket.
    I learn something new everyday.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    You really cant see the long part of it.It is in the case.
    I was suprised as well when I looked at mine.
    Apr 2004
    Brigham, Québec, Canada
    1,529
    Quote Originally Posted by scary132 View Post
    I realize I'm a little late... but I got my 200e front sprocket and some other stuff from Hyperparts.
    http://hyperparts.com/wc.dll?ctwp~it...1~1002~H833426
    Best deal I found.
    Yeah they look to have some great deal. I bookmarked the website.
    I hate this, because of the missing dowel pins I can't continue the rebuild.
    Anyone got a 10 x 20 mm dowel pin laying around??? If not, I will have to order it at the dealer, I'm sure they don't stock this $1,12 dowel pins
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    McDerry is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Maine
    440
    Awesome Parts Source.
    Had been looking at getting new sprockets for my TRX125 (Rear is worn, front is worn and chipped on a couple teeth), in addition to the gasket set. Hadn't seen any vendors listing it all (some had the front sprocket, some the complete gasket kit, etc.) Ran me $112 plus shipping charges (est $12) For front and rear sprocket, chain and the complete gasket kit (just refreshed the valves and to switch the front sprocket) from Hyper Parts. MFG supply was listing the front and rear sprocket and chain for $90 alone. Would still have to hit up DennisKirk(or equivalent) for the complete gasket kit for another $35-$40 plus shipping, but mind you they didn't offer a front sprocket.
    As for the dowel pin, I'd hit up Beatrice Cycle/DRATV. He has a ton of those smaller engine parts people loose and his shipping is descent (USPS).
    Apr 2004
    1,529
    Today I received a 200x cam . Still waiting for the back-ordered front sprocket to arrive
    Anyone know if the 200x valves springs are stonger on the 200x head? I don't want the valve to float when I wide open on the trail.
    Sep 2005
    Lipetsk, Russia
    2,824
    You can probably stick stiffer XR200 springs into it. If not, I am willing to bet the 200X springs are stiffer, due to the bike's purpose.
    I'm back in the USSR...
    Apr 2004
    1,529
    So I checked if the 200x use different valves springs and Bikebandit list the same parts numbers for all the valves springs between a 82 200e and a 83 200x. So I will be ok.
    Apr 2004
    1,529
    Quick question. On the rear right dowel pin between the cylinder and the head there is an o-ring around it. When I dismounted the engine there was a green o-ring, but it was cut. Was it the right o-ring? Is it a black o-ring that goes there?
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Yamada View Post
    The green o-ring is the proper one for that dowel pin. The reason for that o-ring is to seal that dowel so that the oil will get to the head / cam, ect. The oil comes up along that stud to the head / cam.
    Howdy
    Apr 2006
    Maine
    440
    As howdy said its a pressurized journal for the overhead cam. You want a o-ring around it prefferably uncut.
    Apr 2004
    1,529
    Thank you Howdy and McDerry. I knew the cut o-ring was not a good thing because when it was running oil was dripping around the head gasket.
    Apr 2004
    1,529
    Today I went to a motorcycle salvage yard and found the dowel pin that was missing. What was funny is that the guy just went behind his working table, pulled a head that was on a pile of part, removed the dowel pin and gave it to me. He said, my wife don't want i sell these part, she just want me to gave them. Just give me $1 and it'll be ok.
    At least now I know where to get parts for my trikes, he had at least 5 atc-200 ( don't the model, just no x), maybe 2 250sx, 1 atc-110, 1 atc-125 ( with the horizontal engine), 1 yt-125, maybe 2 ytm-200 or a ytm-225. They looked to be complete except for some missing pull start and flat tires.
    Tonight I will rebuilt the engine and if everything goes well, put it back into the frame and try to start it.
    Apr 2004
    1,529
    Well, I just finished to put the engine back together. I did a compression test and the result is 135 psi. I think it is pretty good. Maybe tomorrow i'll havethe time to put the engine into the frame and fire it for the first in 4 months :woot:
    I small problem I encountered is that I use a 200x cam in the 200e head. The manual call 0.08 mm of valve clearance for the 200x and 0.05 mm for all the other models. I set the valve to 0.08 mm, do you think it is correct?
    Apr 2004
    1,529
    I just fire it!!! It fired after 5-6 pull of the cord. I only had a fouled plug so I think with a new plug the engine will run like a champ. Now all I need to do to ride it is change the drive sprocket and put a chain. I can't wait to take a ride!
  15. #30
    Sep 2006
    S.E. LA
    700
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
