Thread: 1983 200e big red front end on 1984 200es big red
    texas
    19
    i have a 1984 atc200es big red that needs a front end. i found a 83 atc200e big red that im thinking about buying for parts. will the forks and whole front end from the 83 200e big red bolt strait up to the 84 200es? what all can be swapped out between the two? fenders? please help as i dont need to spend the money on the other bike if the whole front end wont swap.
    thanks,
    John
    Tionesta, PA
    5,743
    front forks and axle and brakes and front and rear fenders are all the same and can be swapped. Racks are the same gas tank is the same (different decals on fenders and tank of coarse). really the only difference is the frame, and the engine and power train and rear brake setup.
    texas
    19
    thanks!!
    hey thanks, i appreciate that info. i guess im gonna get it. shame to use it for parts cause it looks to be in pretty good shape but i need to get the 84 running because its used for work. cant use the 83 for work since its chain driven.
    thanks again,
    John
    Nov 2007
    tx/damon u.s.a
    42
    i put a 200m front forks on a 185s looks like a little kids big wheel but it swaped fine
