Results 1 to 3 of 3
Thread: oil injection
    Mar 2003
    59
    oil injection
    this bike will not idle no matter how i adjust the carb and cable brand new oem airbox and filter carb clean new spark plug theres delayed throttle responce and sometimes bogs down when you let off the gas for a second and gas it again like its getting flooded what does it sound like is wrong ??
    fist of all how can i tell if the oil injection is working and second how do i adjust it
    Dec 2006
    St. John's Newfoundland
    1,587
    I would just disconnect it and mix my gas.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    The only way you tell if it's working is to pull the hose off that feeds the carb from the pump within your case and see if it drips every so often. You MUST premix a tank of gas and drain the carb of unmixed gas before you try this. A manual shows a pumps per minute test to perform or a CC's per minute to receive.
    Honestly, Yamaha has a very reliable oil injection - I have NOT heard of many failures. But, they set it very rich to cover there butt on engine failures. Thats why most guys block it off and run Pre Mix.
    EDIT - By the way, that injection won't cause your engine to run poorly - UNLESS it is suddenly WAY too rich at which point your engine will smoke and your plug will foul, or it fails, or clogs and your engine seizes from lack of lubrication - thats it bro!!!!!
