Results 1 to 15 of 29
Thread: 76.44 mm piston what CC's
    Oct 2007
    corinth ms.
    77
    hey guys, what kind of cc's are we talking about? from what I've read a 250r with big bore kit is 72.00 mm, makes it a 295 cc. Is this right? So what is a 77.44 mm? thanks Joe
    Nov 2006
    southern oregon
    2,338
    what year R? 77.44mm Bore? or 76.44mm bore? your post includes both....
    2-stroke lover
    Nov 2006
    southern oregon
    2,338
    An air cooled is 295.3cc with 76.44 bore.... a water pumper is 330cc with that same bore
    2-stroke lover
    Apr 2007
    You have to include the stroke of the engine into the equation.The aircooler stock has a 64.4mm stroke and a 70mm piston it takes a 76mm piston to get 300cc out of the motor without stroking the crank. The 85 R had a 66.0mm bore and a 72mm stroke so therefore you may get a 295 out of that with a 72mm piston.
    Airfoolers RULE!!!
    Oct 2007
    corinth ms.
    77
    84 250r
    sorry guys, it's early, it's a 84 250r with a big bore kit. with a 76.44 mm piston.
    Quote Originally Posted by yellowbeard View Post
    so you didnt know you had a 300 kit huh.. that like getting a present right there..good luck on it .. these guys will point you in the right direction!
    it would be better for you and us if you could keep all your post's in one thred
    Oct 2007
    corinth ms.
    77
    Thanks
    will do, just i'm new to dealing with the big bore kit. will try to keep my questions to a min. and all in one thread. real interesting, thanks for the info. Joe
    NO NO Please ask your question's these guys will answer!!
    Nov 2006
    southern oregon
    2,338
    Questions are good... post as many Q's as you want...I think what Raffa means is try not to post multiple threads on similar topics and search to see if a topic has already be covered before starting a new one... Old threads can easily be revived by adding a new question that relates to the topic..
    2-stroke lover
    Jan 2004
    Palmetto,Florida
    2,300
    I Think SYKO has some info on the Air Cooled Thing's as well .. Raffa .. you have one of those ATC's also ?
    "07" DR650 Suzuki Dual Sport
    Nope.. I built one for Bruce's ice racer...Mr hondaline had the parts on the shelf for his particular build..I really hope to see it on the ice this year..
    scrawny's Avatar
    scrawny is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    WI
    181
    yep you are right, 295.3907 etc.....
    thanks for the sig
    sponsorhouse.com profile: http://sponsorhouse.loopd.com/Member...er65/Home.aspx
    Oct 2007
    corinth ms.
    77
    72mm = 295cc
    hey guys, 1upfront has it posted ^ that 72mm = 295cc. what I'm looking at is 76.44. So, if 72mm is 295cc what is 76.44? Joe
    Oct 2007
    corinth ms.
    77
    ok re-read cr480's post said that 76.44 is 295cc. been reading up on all the old threads about the big bore kit. still have no idea what ya'll mean by decking the cylinder. my cylinder, shouldn't it be already decked since it has had a 76.44 mm piston already.
    Nov 2006
    southern oregon
    2,338
    Well by the sounds of it the new replacement piston is a bit different from the original... So even though the bore size is the same as your old piston, the piston height is not... The deck height is the distance from the top to the bottom of the cylinder... So since the distance from the piston pin to the top of the new piston is reduced the cylinder deck height would need to be reduced the same amount for the piston to reach the top of the bore at tdc again.
    2-stroke lover
