Results 1 to 13 of 13
Thread: Yamaha tri-z 125, tune up?
    Jun 2007
    Washington
    115
    Hey there two stroke fans-
    Alright i am a little bit slower in the 2 stroke field then the 4 stroke. but im a fast learner, my buddies dad owns a Yamaha tri-z 125. auto clutch, oil injection i believe.
    but the trike looks to be in cherry condition, im sure hes the original owner, the tires still have the rubber feely things on the sides. but its been sitting so long i know all fluids need to be replaced, carb should be rebuilt.
    but what am i missing? oil pump adjustment? syncing the carb and oil pump together? what do i need to know to get this back in action?
    Thanks
    Aug 2004
    Ab Canada
    4,368
    If it hasn't been run, and is in as nice of shape as you say,,,i wouldn't worry about the oil pump sync, really, if it hasn't been run why would the cable stretch? but then again, its easy, just pop the cover off and see that the lines on the pump housing, and wheel (that the cable clips into) line up at WOT and full close,,, Make sure the air filter hasn't disintegrated n fallen apart,,,lube the chain up, giver the beans.
    1985 Tri-Z-
    burnoutboy's Avatar
    burnoutboy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    New Zealand.
    352
    im pretty sure the oil pump is non adjustable. most people ditch it and run premix
    wanted.. 84 atc70 fuel tank
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Quote Originally Posted by burnoutboy View Post
    I did this with my Blaster, something about relying on a pump mixing my oil and gas didnt sit well with me. The Yt's had a cable running some kind of synchronization off the carb? My blasters was a gear driven type.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Aug 2004
    Ab Canada
    4,368
    Most people read into it too much, iv never had a problem with an oil injector pump on any bikes i have worked on,,
    1985 Tri-Z-
    Central PA
    1,952
    Yeah I never had a prob either, but when it comes down to it you have one little part that if goes so will your motor. It should be alright, I just cant trust something like that when you can just as easily mix your fuel and have peace of mind. Just my .02
    PastRides
    SOON MY PRECIOUS!
    Jun 2007
    Washington
    115
    ok so enough with the oil pump, what else goes on with these things? what jets should be in the carb?
    and about that carb, it does the same thing as the 4 stroke one, then once the mixture is in the case the oil mixes in right? but what if you disable the oil pump? do you need to change the jets or anything to allow the use of mixed gas?
    Now on a completely different but slightly the same problem, i have a honda NC50 scooter (i know i know its bad a**) but i disabled the oil pump and ran mixed gas in it. but i have no idea how to tune the carb to run right, it will sometimes idle, but if you work the throttle you are able rev it really high then it just dies. so if anyone has an tips that would be cool.
    im going to look for the manual for the Tri-z for all the maintenance.
    Dec 2007
    Prescott AZ
    99
    No you dont need to rejet! and I dont understand why everybody "rebuilds" the carb theres nothing to rebuild! Just clean it thoroughly and put it back together!
    Current bikes:
    85 1/2 Tri-Z (black/red)
    84 T3 restored
    84 T3 unrestored for gettin'
    84 T3 money pit
    86 350X 13.5:1 full race
    84 250R beater
    96 blaster CT sonic 240 kit 38mm airstryker carb 42HP!!
    Past bikes:
    85 TRI-Z
    84 200X
    87 200X
    86 350X
    82 250R
    84 250R beater
    84 TRI-MOTO 125
    83 ATC 110
    70 US 90
    87BW 200( I know its not a trike but...)
    Mar 2007
    lakeville ma
    605
    Quote Originally Posted by TJ BIG DAWG View Post
    i use to think the same thing but i had a xr 250 that never ran right but after a needel and seat it was night and day
    NO 3 WHEELERS CURRENTLY SOLD THEM ALL
    02 GSXR 240 kit STRECHED
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    670 ho skidoo powered banshee
    1985 nacs kx 80 race quad
    Dec 2007
    Prescott AZ
    99
    Quote Originally Posted by Black86tri-z View Post
    yeah but I'd hardly call that a "rebuild"...
    Current bikes:
    84 T3 restored
    84 T3 money pit
    84 250R beater
    Past bikes:
    85 TRI-Z
    84 200X
    87 200X
    86 350X
    82 250R
    84 250R beater
    84 TRI-MOTO 125
    83 ATC 110
    70 US 90
    Jun 2007
    Washington
    115
    so you wouldnt call taking the carb completely apart, cleaning it and putting it back together a rebuild??
    i am just asking questions, i dont know what the 2 strokes need. let not freak out about what needs to be done with the carb. i would just assume that with adding oil into the gas you might have to go up one main jet, just like if you are removing your snorkel or adding exhaust to your bike, you need to adjust the carb so you dont run lean or rich.
    Central PA
    1,952
    No you shouldnt have to rejet, the the oil should mix with the gas in the carb, not the cylinder or bottom end. I am quoting this from a blaster as I have never worked on your model trike before, but it should be about the same deal.
    PastRides
    SOON MY PRECIOUS!
    hadar's Avatar
    Rock Island IL
    699
    You can run premix and the oil injection to be on the safe side. I know a guy that does it all the time and claims that it's the secret to long life for the yt. He's been running his 175 like that for years. And seeing how back when I had a yt125 and blew it up about 3 times running just the oil injection, he might be right. Smokes like crazy but at least you know it's getting oil.
