I have this milky grey stuff coming out of my ehaust when i try to start my tri z? wtf is it? i replaced the water pump seal! could it be head gasket?
ANY INFO WOULD BE AWSOME!!!! thanks
Have you run it through water recently? or powerwashed the crap out of it?.
COuld you possible get us some pics??
Trikes:
1973 Honda ATC70-orange!
(2)1985 ATC70
1985 Big Red 250
1985 250R
What do you want a pic of?
no i havent washed it yet i dont understnad would it could besides a head gasket b/c the oil and water looks good i think it has a bad head gasket b/c everything else is clean so its got to be mixing in the top of the head and shooting out the exhaust! stupid yamaha its not giveing me a good sign being my frist one!! :x
Normally when you get a head gasket leak, you dont get water in the cylinder, to get into your exhaust. It usually shows up as compression leaking into your cooling system. If you do have a leak between cylinder and jacket via headgasket, youll be able to see it, when you take the radiater cap off, and rev it. Everytime you rev, it will blow coolant out. With the cap on, it will blow coolant into the overflow everytime you rev it. Youll also have a gas/oil film in your coolant.
Pop the radiator cap and see if its milky too . Remember if you run a bike with a blown headgasket eventually all the coolant will leak out and then....Blamm-O
Send us a pic of the exhaust stuff that's leaking. I wanna see what it looks like.
Trikes:
(2)1985 ATC70
1985 Big Red 250
1985 250R
Maybe your sucking water through the intake, I get this with my TS185 occasionally... Doesn't harm it much, but then again i dont care about it.
1986 ATC 250R(for sale), 1963 AceCraft boat w/40HP Evinrude, 1981 Arctic Cat El Tigre' 440 L/C, 1992 GMC Safari Van.
How would it be possible to suck the water through the intake? especially on the Tri-Z(85's at least), the water doesn't go near the intake...as far as what I can see looking at the motor.
Trikes:
(2)1985 ATC70
1985 Big Red 250
1985 250R
dang 81 r i belive it was her water cooled engine that got to him?
lmao man im about ready to give up on it!![]()
bad headgasket or cracked cylinder or head
Back on 2 wheels for now!
clean 86 350x for sale.
Set up a camera. Your neighbor may be sneaking in at night and using the muffler for purposes other than it was intended for.... :shock:
It's water and oil getting together somehow. You say it's your first yamaha. was it setting a while?
1986 Tecate
1984 Tecate
1985 Tri-Z
1986 ATC350X
1985 ATC250R (2)
1985 ATC125M (2)
1982 ATC70 - Original Owner
175 TriMoto Frame with Pro-Tec Rear Suspension
3-Wheelin' since '82
Hemi challenger71,I would like to know how you are getting water in your intake to,the TS 185 was air cooled. but it would be dam near impossible for a liquid cooled to do that either. Are you talking about like if you wash it or run it through a mud hole?
ATC350X,ATC70,1991 RM 250,XR500,TM400,TS400,Foreman400 4X4,Polaris 425 Magnum,ATC 90, 1982 175,1973 Honda Trail 90,1980 CR80,1981 CR80,
