Results 1 to 15 of 18
Thread: Lifan Topend on 125m
    burnoutboy's Avatar
    burnoutboy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    New Zealand.
    352
    recently bought an 85 125m. having an issue with it:
    when going down a hill and engine braking, it starts smoking when I accelerate again. it only smokes for about 3 seconds or so.
    what would the most likely could the cause of this be?
    can those lifan top ends bolt on to these motors? they seem to be good quality and well priced.
    regards
    wanted.. 84 atc70 fuel tank
    Aug 2006
    Texas
    997
    I had the same thing happen on my old 85 125M. Im guessing the oil would rush to the top end finding a way into the cylinder. Mine would sometimes seize when on a really steep decline. It was hell to start and when it did, smoke everywhere for a few seconds. Funny, there was little to no smoke during normal riding.
    84 Honda 200ES Big Red
    burnoutboy's Avatar
    Apr 2006
    New Zealand.
    352
    do these things have a automatic decompressor? theres not alot of compression when i yank the pullcord.
    do you know anything about those lifan topends?
    burnoutboy's Avatar
    Apr 2006
    New Zealand.
    352
    and my one doesent smoke at all exept for when engine braking down a decline.
    i liked your wheelie vids on youtube haha.
    Kentucky
    2,294
    Time for a new set of rings.
    Tionesta Trikes ATC 450R
    86 250R
    86 Tecate-3
    83 ATC 70
    85 Big Red
    81 KLT 200
    85 250SX
    Apr 2006
    Crestview, Florida
    2,429
    what color of smoke? is it realy cold out when it does it?
    burnoutboy's Avatar
    Apr 2006
    New Zealand.
    352
    blue... nope just normal hot sunny day. definatley need a top end. now im just trying to see if i can use a whole lifan top end.
    Dec 2007
    Indiana
    235
    Sounds like an oil ring to me. When you engine brake, there is less compression against the rings which could allow that small amount of oil into the cylinder.
    Not sure if these have the decompression or not.
    Another off that wall idea...didn't accidentally put 2 stroke gas in it did ya? lol
    -Phil
    Columbia
    5,131
    Do a compression check before you go to extremes.............
    Apr 2006
    Crestview, Florida
    2,429
    it would be cheaper to slap in a new topend kit.
    Jackson MI
    1,688
    I would put a new set of rings In. It's about the only reason you will get blue smoke on deceleration. Oil In the cylinder at the time a compression check Is done will SOMETIMES give a false reading because the oil works as a sealer for the rings.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    scrawny's Avatar
    scrawny is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    WI
    181
    if its the 110 style motor, they only have one valve seal on the exhaust side, so they will smoke quite a bit no matter what. do a compression test, she might be clapped out.
    thanks for the sig
    sponsorhouse.com profile: http://sponsorhouse.loopd.com/Member...er65/Home.aspx
    Sep 2007
    oregon
    2,292
    My turd warrior did this , and all it needed was rings...
    Rennat_2006's Avatar
    Rennat_2006 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2004
    194
    My 110 did this and got to the point it would smoke all of the time. I just put a new top end into it.
    -1983 Honda ATC110-
    Brand new topend using. Performance cam and some porting/polishing.
    Should be good for another 24 years now!
    -1991 KTM 540-
    Piston turned into grenade inside motor ammit
    -1996 KTM 550-
    Midway through COMPLETE rebuild
    -1997 Honda Cr80-
    Spun crank bearing on trans side ammit
    burnoutboy's Avatar
    Apr 2006
    New Zealand.
    352
    Yeah there is bugger all compression there,,very easy to turn over. really want to do the whole top end while i got it apart...those lifan topends are cheap enough.
    My main question now is will the Lifan topend bolt onto my motor??
    thanks for the help everyone much appreciated
