Results 1 to 15 of 16
Thread: 85R hp in Snow
    iowarotax's Avatar
    iowarotax is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2006
    iowa
    393
    85R hp in Snow
    Yesterday I took my 85R and Quadzilla out on the lake by my house. There is about 6 inches of soft snow on the lake. I didnt put studded tires on either yet. Heres my questions. The R would haul butt up untill 5 gear, then it would lug down and my speed would drop and would have to down shift to keep my speed up. Now the quadzilla would just keep going and gain speed in any gear. It was almost like a snowmobile plowing through the deepest areas. Do you guys notice this on your Rs in snow or is the quadracers horsepower overwhelming the snow? It was night and day riding the 2 machines.
    198? 250 Tiger 198? 200 Tiger 198? Tiger 500 1985 KTM 500 1985 Can-Am mx-lc 250 1988 ATK406
    springville, PA
    6,185
    The Zilla has another 250cc which probably makes that difference
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Jackson MI
    1,688
    That Is what you call torque. The R has a short stroke & Is a small engine that loves to scream (top end horsepower). The LT has a long stroke & Is a big engine, It can be lugged down & still pull (low end torque). Think of It like this, what would pull a loaded trailor easier. A 4 cylinder civic, or a big block truck.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Change your front sprocket to something smaller.That will help some
    Or try some snow 4 Maxxis tires on the rear.
    Apr 2006
    PA
    1,464
    another thing that i always thought about too is theres more snow resistance on a 3 wheeler since the 3 wheels are all in different places. On a quad the front wheels are packing the snow down, and if you ever rode in packed tracks you know its alot easier to go.
    iowarotax's Avatar
    Dec 2006
    iowa
    393
    Ive been riding 250Rs on the lake up here for years and really never had problems getting around. I think the snow is a little crusty and the R is using alot of hp just to keep breaking new ground. As long as I stay in the lower gears Im fine. Riding the 500 spoiled me. That thing never bogs down under load. The R Im running will keep up with the 450 thumpers on top end, but not out of the hole. Pisses me off, they get me out of the hole every time. Is that normal?
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    I think it has something to do with the training wheel.
    Oct 2007
    Oregon
    46
    I went riding yesterday withmy buddy and he has a trx 450r and i was on my 250r. he has some maxxis tires on his which i notice help a ton, i just have the stock tires on my r. he was diffently plowing and going up the hills better than me. my r was just staying on top of the snow peeling out. torque diffently helps in the snow. hella fun stuff tho
    FOR SALE85 ATC 250r
    +6" extended swing arm
    +4" axle
    FMF Fatty Pipe
    DG Silencer
    Cool Head
    Boyesen Reeds
    Keihin Carb
    Wiseco Piston
    K&N Air Filter
    Dec 2007
    Louisiana
    170
    cool
    Not too bad....I wish down here in New Orleans it snowed a little more...would love to ride in the snow
    Daily Driver 1992 Chevy Silverado sitting on 35's
    Toy 1984 Honda 200S
    iowarotax's Avatar
    Dec 2006
    iowa
    393
    Yeah the snow on the lake right now is nice to do long sweeping power slides along the lake shore. Its tacky enough to hold you in a nice groove. On the zilla, wide open top gear throwing walls of snow on all the trees. Heres a pic of the 2.
    nate b is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central WI
    433
    The R Im running will keep up with the 450 thumpers on top end, but not out of the hole. Pisses me off, they get me out of the hole every time. Is that normal?[/QUOTE]
    Most of the time they get me out of the hole too , but I reel em in. They can just launch harder than me without going over backwards, When I do pull the holeshot, its over cause they can never catch up.
    85 atc 250r;
    PSI porting & head mods
    fmf pipe & silencer
    boysen rad valve & reeds
    38mm air stryker
    iowarotax's Avatar
    Dec 2006
    iowa
    393
    I just took the R for a spin on the lake. Alot of new snowmobile trails. It really hauls the mail on hard packed. I dont know if Im going to put the studded tires on or not. Once the snow packs down it doesnt stop all the way through the gears.
    May 2003
    Houston, Texas
    2,409
    Quadzillas are monsters and have at least 15 more HP on a stock 250R and have much much more torque.
    Nothing beats displacement. The zilla engine rev's pretty far too. I love the engine on my '86 R, but my '90 Zilla is a whole different ball game.
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    iowarotax's Avatar
    Dec 2006
    iowa
    393
    Riding the 2 again today and really noticed how much smoother the R engine is than the Zilla. Even my KTM 500 is smoother than the Zilla. Is this normal? As you get into the bigger bore 250Rs, do the start to vibrate like the 500s? The R motor really is like a sewing machine, compared to the washing machine spin cycle of the zilla.
    Oct 2006
    Ohio
    541
    Quote Originally Posted by Darius1502 View Post
    Lt500's and Trx/Atc 250r's actually produce near identical HP numbers according to Loren Duncan of Duncan Racing International, but the 500 does have much higher torque #'s.
    1997 Kawasaki Bayou 220
    2004 Yamaha YFZ450
    1985 Honda 250ES
    1982 Honda 185s For Sale
