Thread: TRI-Z 85 & 86 swing arm
    Sinbad46's Avatar
    Sinbad46 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    Canada, Québec
    232
    Hi guys
    if the Z 85 Swing arm and axle are the same than the 86?
    thanks
    Feb 2006
    Texas
    738
    The axle is. Now there are some diferences on the swingarm, which I'm dying to know exactly what those are. I believe one is in the pivot bolt bearing area.
    If someone knows the details and care to share them, please, go ahead.
    TORKER.
    THOSE WHO SAY IT CANNOT BE DONE, SHOULD NOT GET IN THE WAY OF THOSE BUSY DOING IT...
    Jun 2006
    Ohio
    2,294
    The 85 swinger took a larger outside diamter pivot bearing and bushing.All the parts between the 2 years are the same.The only difference was the pivot bearing size,and bushing size and inner grease seal(on the engine side)..The sleeves bolts trust washers and end caps will all work between the 2 years
    The 86 swinger uses a smaller OD bearing and bushing and grease seal,and is the same pivot bearing as a Banshee uses.
    There is also a cosmetic difference in the swingers between the 2 years.but they will work on both year TRI-Z.
    Raffa posted pics of the differences about a year ago.Search his threads.
    1981 ATC 70
    1978 ATC 90
    1985 ATC 250R
    www.cosmicquads.com
    Sinbad46's Avatar
    Nov 2007
    Canada, Québec
    232
    thanks for helping me
    Feb 2006
    Texas
    738
    Tammy, you're great. Thanks for the details, exatly what I needed.
    TORKER.
