Results 1 to 15 of 17
Thread: 84R left side casing removal
    Jan 2005
    Slatington PA
    4,372
    MAN !!!!
    I have to remove the engine to do so, because of frame (front down tube) interference and shift shaft.
    OH WELL, now I can detail it up nice.
    No wonder you don't see many with custom polished side cases
    I don't think the 5/6's are that way, are they ? Although everything is on opposite sides I think?
    While I'm on engine removal (I did it already) subject, which side have you guys removed motor from? I moved mine back, tilted it sideways/sort of diagonal and removed it from L side, is that the easiest ?
    Dec 2006
    St. John's Newfoundland
    1,587
    I cant remember now but I believe once unbolted the motor almost fell outta the 81R I have. But I noticed my fathers 84 it seems the motor is down in the frame a little.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by Brockey View Post
    Yes, something must be different, in no way did mine almost fall out, took a few different tries till I succeeded and of course the manual says to simply just "remove the engine" like it's a piece of cake.
    I'll post installation pic's on here so it will help others + me. Surely years down the road, if I do have to remove/install again, I sure won't remember how I did it.
    Jul 2006
    my meathod on my 83 R was cussing, yelling, pulling, pushing, ing, that seemed the best way to remove it......
    Apr 2007
    It only comes out from the right side I've done it a million times with these infact I'm going to install my 300r motor today.
    Airfoolers RULE!!!
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by 1upfront View Post
    No it doesn't, it comes out on the L too, I guess you didn't read what I said in 1st post ?
    Do you do yours the same tecnique as me, except on R side ?
    How about you sykolincoln, what side you do yours on, after your done cussing, yelling, pulling, pushing and ing that is
    I'm going to get this motor install/remove down to a science, I certainly don't want to practice it on a freshly repainted frame (that's next year) so like said before, will post pic's when I feel I found the easiest way.
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    you got LUCKY getting it in/out of the L side............
    Apr 2007
    Yes same way only from the Right side I was never able to get it out from the left side without scratching the frame and motor
    Airfoolers RULE!!!
    Jan 2005
    RI
    2,530
    i wrap teh frame is that styrofoam looking paper when installing motors.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Apr 2007
    I use a few layers of 2 inch masking tape on trouble areas but what I'm saying is it's damn near impossible to get the 83-84 motors out from the left side without damaging something I don't know how he did it.
    Airfoolers RULE!!!
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by DeePa View Post
    YES! Good idea DeePa! That or that black rubber foamish copper pipe insulating tubing that is not costly.
    Heck , I can borrow that from some of my pipes in my basement!
    Jan 2005
    Slatington PA
    4,372
    MAGIC!
    I'll show you if I can accomplish getting it back in the same way.
    Apr 2007
    Hahahahaha cool man.
    Airfoolers RULE!!!
    Jan 2005
    Slatington PA
    4,372
    What's odd is the fact that Honda tells you to remove the shock resivoir, there is no reason to do that UNLESS you are removing the engine from the L side and even then you don't have to remove it, just loosen clamps and turn it counterclock wise, out of the way.
    We shall see though, I'll try it from R and L since frame is not painted and has nicks, see which way I like more.
    Apr 2007
    Hey Huffa I just put my motor in from the right side.
    Airfoolers RULE!!!
