Results 1 to 7 of 7
Thread: tri-z steering stem bearing???
    Feb 2005
    suffolk,va
    109
    I bought the tapered bearing kit from dad's and i'm trying to install the upper race in the steering stem. I removed the old ball bearings and the piece they sat on. There is still another lip in there and if i set the race down in there it will stick out of the neck some. It looks like i need to get rid of that lip and then it will set down in there all the way. Has anyone ran into this problem? I wish i had a camera i would take a pic of it. thanks
    chris
    Jan 2005
    RI
    2,530
    i just went through this, and everythign still went together fine even though there was some of the race exposed over the top of the frame.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Aug 2005
    Lockport, NY
    2,395
    DADS has these? How much for the kit? I need to do the same!
    Feb 2005
    suffolk,va
    109
    It's been a while since i bought it and i can't remember how much it ran me. Just pm him and he'll respond quick. later
    chris
    Mexico
    9,019
    Did you ever figure this out? I'm having the same problem.
    Feb 2005
    suffolk,va
    109
    You can actually run it like that with no problem. The only other thing you can do is have someone extend the upper part of the steering neck to cover the bearing race completely.
    They all stick up... your dust cover will cover it,, and there will be no problem running it like that..
