Results 1 to 3 of 3
Thread: 98 zr cat suspension?
    Mar 2007
    lakeville ma
    605
    how do i put more preshure on the ski's it has only 96 studs and i have 2 sets of carbides 4 and 6 inch both dont make it steer for dam i have 2 other machiines same chassis in my riding group and they turn way nicer any help would b awsome
    NO 3 WHEELERS CURRENTLY SOLD THEM ALL
    02 GSXR 240 kit STRECHED
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    670 ho skidoo powered banshee
    1985 nacs kx 80 race quad
    Jun 2006
    Willow, Alaska
    1,337
    You can adjust the limiter straps on the rear suspension, they will put more or less pressure on the skis depending on how loose or tight the straps are. I dont have a manual on hand, but if you have one, it should explain how much to adjust the straps and it will be under 'suspension'. I have a manual somewhere, Ill try to find it and post up if you dont have one.
    -Nick
    1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
    98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
    joe_f7's Avatar
    joe_f7 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2008
    SE wisconsin
    227
    just tighten them till you have the feel you are looking for. should be two 3/8" nuts that pull them sucking the front of the rear suspension up.
    1986 Kawasaki KXT 250 tecate
    ported, FMF pipe, DG silencer, boysen stage II reeds, 39mm keihin PWK, T4 thumb throttle and front master
